San Diego Area - Page 406 - JeepForum.com
 47Likes
post #6076 of 40766 Old 03-19-2008, 09:06 AM
Jeebs
2015 JK Wrangler
Originally Posted by dwedeking View Post
ok, I looked at my calendar and can do Tuesday in the gaslamp. I'll schedule some morning meetings in San Diego. Carlsbad to San Diego is way easier than LA area where I do a lot of driving.
I'm thinking I may be able to do a run on Thursday. Where you planning on going?
Either Coral Canyon or Anza Borrego. I'm not particular on which one we hit up. Steve was going to check his schedule too and see if he can make it this week. Kory is gonna make it out as well.
Jeebs is offline
post #6077 of 40766 Old 03-19-2008, 09:46 AM
merkur92
I can make the camping trip,just need to be able to park a 38' motorhome somwhere.Jason if we are leaving on friday to go camping,thursday might be to close.
2002 Overland wj,JK rubicon dana 44s, np231, 6" rock krawler long arm lift,ARB front bumper,warn winch,JCR rock sliders,33" toyo M/T,s.
merkur92 is offline
post #6078 of 40766 Old 03-19-2008, 09:57 AM
MooJr
Does anyone know what size bolts are on the windshield frame on the outside? I need to get 4 replacements bolts. Iv found some online but they dont have a size. http://www.jeep4x4center.com/product...number=6035757. I just want to head to the hardware store instead of ordering them offline for that price.
Your local neighborhood Noob - Nate
MooJr is offline
post #6079 of 40766 Old 03-19-2008, 10:03 AM
Jeebs
2015 JK Wrangler
All those hinge bolts are 5/16" National Course thread. If you're keeping the OEM hinges, you can get tapered head allen key bolts about 1 - 1.5" long. A popular replacement is a round head allen key bolt, but again, if you use OEM hinges with this type of bolt, you'll need washers & I'd recommend 5/16" grade 8 washers - the standard softer washers will bend into the hinge bolt hole taper.
From the back side, if you use nuts, use nuts with a captive wide washer or use a fender washer to spread the load on the inside of the tub, otherwise a plain nut will pull through. I prefer making a plate about 1/4" x 4" x 1" and drill/tap two 5/16" threaded holes in each - I use one of these for every two nuts to spread the load.
Jeebs is offline
post #6080 of 40766 Old 03-19-2008, 10:20 AM
MooJr
So you say there is a nut on the back? I though they just screwed directly into the frame. I did notice the bolts would spin but wouldnt come out. One got trashed. How do you get to the nut then?
MooJr is offline
post #6081 of 40766 Old 03-19-2008, 10:35 AM
Jeebs
2015 JK Wrangler
Thats only if you lose the nut on the back. You should be able to just screw a new bolt right in.
Jeebs is offline
post #6082 of 40766 Old 03-19-2008, 10:45 AM
MooJr
Like I mentioned I got 3 out of 4 to break loose, but they just spin. I was thinking of just drilling them out and replaceing them, but if i can get to the back somehow and save them then ill do that.
I got some milk crates at work if anyone needs some drop me a line.
MooJr is offline
post #6083 of 40766 Old 03-19-2008, 12:50 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If these are anything like the lower windshield torx head screws on my '91 YJ, do yourself a favor & drill them out! Period!
On mine, not only were the torx head screws loctited, they also had nylock nuts AND they were spray painted like crazy with some sort of sealant. They were a MAJOR PITA to try to back-out.
I drilled them. It took ~1-2 minuted per bolt. Plus, who wants to reuse boogered-up old torx head screws again? Nobody.
Joe Dillard is offline
post #6084 of 40766 Old 03-19-2008, 01:16 PM
Jeebs
2015 JK Wrangler
So they broke loose and are spinning but not backing out? Sounds like you broke the nut on the inside of the windshield frame and made yourself quite the project! I second what Joe said though, just drill'em out. Thats what I ended up doing.
I'll take at least one of the milk crates to hold fluids on the trail.
Jeebs is offline
post #6085 of 40766 Old 03-19-2008, 02:36 PM
MooJr
Thats what i feared . Ill pick up some replacements and if someone can let me borrow their drill ill get them out. Now about the nuts on the back... I dont know how to even get in there. Iv had my windshield down a couple of times and i dont remember there being a space.
Okie sounds good im hoping to get at least 6 crates
MooJr is offline
post #6086 of 40766 Old 03-19-2008, 03:14 PM
jbolty
jbolty's Avatar
Won't the fluids leak right out through the holes in the crates? I would just use the jugs it comes it.
jbolty is offline
post #6087 of 40766 Old 03-19-2008, 03:27 PM
Jeebs
2015 JK Wrangler
I'm heading home now to do more fluids changing and other junk. You are welcome to head over and we can figure out what ya did.
Jeebs is offline
post #6088 of 40766 Old 03-19-2008, 03:29 PM
MooJr
Sounds good. im off at ~400 ill head over as soon as i get out of my cammies.
MooJr is offline
post #6089 of 40766 Old 03-19-2008, 07:11 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
1) I'm in for the meeting because I want to support the 4x4 causes.
2) Depending on how many others want to go.
3) either or
4) I feel like I live there on the weekends already
5) Camping in good
6) If I can get time off work..
Group W Bench
CRAWLING 98 is offline
post #6090 of 40766 Old 03-20-2008, 07:58 AM
BrandonTJ
BrandonTJ's Avatar
1. Not I
2. Ditto
3. Either
4. No can do
5. Nope
6. Nope
Sorry guys, I won't be much fun for a while. Just got married and am looking to change jobs and (possibly) move soon. Will come out and play when things settle down a bit. Have fun and don't break anything expensive.
Brandon
Ham - N6VAN
BrandonTJ is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
