San Diego Area - Page 398 - JeepForum.com
 47Likes
post #5956 of 40763 Old 03-15-2008, 06:38 PM
jbolty
jbolty's Avatar
Originally Posted by NewBlue90 View Post
No, I haven't pulled it out yet. I'm actually still debating whether to keep it or not. It was a steal of a deal. Regularly that would have been $485 and I got it for $220. I'm just questioning whether I really need it or not.
We going somewhere tomorrow?
Maybe I'll buy it from you?
what are the spec?
btw, I got that sound bar from Tab today. In good shape but really, really, dirty.
jbolty is offline
post #5957 of 40763 Old 03-15-2008, 06:41 PM
jbolty
jbolty's Avatar
Originally Posted by 4x4grey88 View Post
Is it me or is this thread getting (lets say) a bit slow. I know that we all have our things to do but it just seems like we are all doing it at the same time.
I know that I have been working my butt off this week.
Anyways,
Happy St. Patrick's Day to ya.
Has been a bit of a lull.
I started taking my shocks off the other day for my spring installation, then got sidetracked by having to replace the post holding my gate up. Digging out a 2 foot deep plug of concrete sux.
jbolty is offline
post #5958 of 40763 Old 03-15-2008, 06:51 PM
Jeebs
2015 JK Wrangler
what are the spec?
Specs:
33 Gallon
1.6HP
150 PSI
Built in regulator
SCFM Delivery At 40 psi: 6.3 SCFM
SCFM Delivery At 90 psi: 4.9 SCFM
Ultra Quiet (claims to be under 78 decibels)
The tool kit:
10 pc. kit includes 3/8 in. ratchet wrench, 1/2 in. impact wrench, air hammer and 3/8 in. 25 ft. air hose - plus accessories.
Ratchet wrench features:
# 160 RPM free speed
# 45 ft./lbs. of torque
# 1-1/8 in. ratchet head lets users get into tight places
# Front end exhaust directs air away from user
Impact wrench features:
# 1300 impacts per minute/7000 RPM free speed
# 230 ft./lbs. torque
# Built-in power regulator
# Pin type clutch and ring type socket
Air hammer features:
# Uses standard .401 shank chisels
# Alloy treated barrel and heat treated piston for smooth, fluid motion, longer life
The toolkit has all kinds of adapters and other stuff with it too.
Jeebs is offline
post #5959 of 40763 Old 03-15-2008, 06:54 PM
jbolty
jbolty's Avatar
let's make a deal
tty tomorrow
cheers
Specs:
33 Gallon
1.6HP
150 PSI
Built in regulator
The tool kit:
jbolty is offline
post #5960 of 40763 Old 03-15-2008, 07:06 PM
MooJr
Anyways,
Been running around since I got back from Florida. I did get my tires installed yesterday, took 3 hours because they got swamped but they are on there and look good.
Edit: Happy St. Patrick's Day to All!
Your local neighborhood Noob - Nate
MooJr is offline
post #5961 of 40763 Old 03-15-2008, 07:20 PM
premo
if you're interested in selling that compressor jason....let me know. thats if jeff doesnt take it of course
-Scottish proverb
premo is offline
post #5962 of 40763 Old 03-15-2008, 07:40 PM
Jeebs
2015 JK Wrangler
Steve and I are planning a possible snow run tomorrow. Right now the snow level is supposed to be down to 2500 ft. Raise your hand if you are interested!
Jeebs is offline
post #5963 of 40763 Old 03-15-2008, 07:51 PM
jbolty
jbolty's Avatar
I will be, if I get my suspension put back together in time
I might need some brake bleeding help.
jbolty is offline
post #5964 of 40763 Old 03-15-2008, 09:22 PM
merkur92
I am in,lets go play.
2002 Overland wj,JK rubicon dana 44s, np231, 6" rock krawler long arm lift,ARB front bumper,warn winch,JCR rock sliders,33" toyo M/T,s.
merkur92 is offline
post #5965 of 40763 Old 03-15-2008, 10:16 PM
jbolty
jbolty's Avatar
Ok, got the rear springs and shocks in. Just have to torque everything. Took about 2 hours. The front should go faster, since it will be daylight.
As long as you guys are not going super early, and the weather is cooperative in the morning I should be able to go on a run.
I have some extended brake lines to put in and I might need help with bleeding them. But, I don't have to put them in right away. The original lines reach, but just barely.
jbolty is offline
post #5966 of 40763 Old 03-15-2008, 11:08 PM
Jeebs
2015 JK Wrangler
You know, if you used Air Tools with an Air Compressor it would've gone a lot quicker
EDIT: That was Steve....
Jeebs is offline
post #5967 of 40763 Old 03-16-2008, 12:18 AM
Jeebs
2015 JK Wrangler
I put new tires on tonight and you wouldn't believe the change! Check it out!
Isn't it crazy how much tires can change the look of your ride??
Jeebs is offline
post #5968 of 40763 Old 03-16-2008, 12:47 AM
StvDiego
No it wasn't, prove it, so there
I put new tires on tonight and you wouldn't believe the change! Isn't it crazy how much tires can change the look of your ride??
Ummm, yeah, OK... so it went from blue with envy to silver with bling, joy and real round headlights all over a set of tires??
wow
This message has been deleted by jbolty. Reason: I have a rattle
Fixed it for ya
And on a serious note, sorta, the weather in downtown is cold and dry, drove through a thunderstorm with lightening and all that on the way back from Poway, weather radar shows snow in the mountains.
I'll check in the morning and see how the weather is and go from there, maybe a late breakfast and a run up Palomar if there's snow up there or just go somewhere to check out Jason's aggressive, 31" off-road tread tires...
StvDiego is offline
post #5969 of 40763 Old 03-16-2008, 01:22 AM
MooJr
Im in! send me the details
MooJr is offline
post #5970 of 40763 Old 03-16-2008, 01:38 AM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Are you going to post the real pics??
Group W Bench
CRAWLING 98 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
