San Diego Area - Page 2416 - JeepForum.com
 46Likes
post #36226 of 40700 Old 03-30-2014, 04:41 PM
jbolty
jbolty's Avatar
Originally Posted by RikRotorhead View Post
Yeah I only used them one time, the first day I put them on the Jeep. The first run out I disconnected them and never connected them again. I found the pins in my console.
All my spring bushings are new, I have YJ springs not CJ springs, and I run a 12.50 inch tire on only a 2.5 inch lift. I have no body roll at all.
I need to get those rear shock extenders on and welded, then new shocks all around. Then I'm ready to wheel again.
Same for made. Made some quick disconnects and kept forgetting to hook them back up. I did find out a couple weeks ago that coming into a turn at about 45 with no sway bar and 9psi in the tires is an adventure.
What extenders do you have? The MORE brackets raise the top, no welding. Just one hole to drill for the locator pin.
They cost about $90 but would be pretty easy to make.
jbolty is offline
post #36227 of 40700 Old 03-30-2014, 05:53 PM
RikRotorhead
I have something similar, but you have to use a bolt for the shock.
Problem is, the part with the pin does not reach far enough to go into the frame. The stock mount is on a bracket of some sort and the pin touches the frame but isn't long enough to require a hole.
They look basically the same......
Name:  photo(163) (Medium).JPG
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #36228 of 40700 Old 03-30-2014, 09:39 PM
premo
So you know, if you text me a pic, it'll be ~3/4" x 3/4" since my cell is so ancient.
Got side tracked with other projects today. I'll give you a jingle when I'm in the garage next. Thanks again!
-Scottish proverb
premo is offline
post #36229 of 40700 Old 04-01-2014, 02:00 PM
Xpress
I'll never forget the day that I neglected to hook up my quick discos. The YJ doesn't maneuver around rice *******s as quickly without it on
Rik you need to update your Jeep profile
All about that unibody life.
Xpress is offline
post #36230 of 40700 Old 04-01-2014, 04:36 PM
RikRotorhead
What needs updating?
RJC#512
post #36231 of 40700 Old 04-01-2014, 09:07 PM
BigD97TJ
I rode most of the time with my sway bar disconnected before I went antirock. Minor loss in handling wasn't usually worth spending the time to connect back up.
I love the antirock now, took a couple days to get use to the way it handled, but I'll never go back!
BigD97TJ is offline
post #36232 of 40700 Old 04-01-2014, 11:06 PM
RikRotorhead
Yeah in a TJ or JK the sway bar is important. In a YJ it's dead weight with wide tires and tight steering.
So I modified my shock extenders, now they just need to be welded in place and I can get new shocks.
I cut off the excess on the rear axle u-bolts while I was under there. They hung up on rocks a lot. The were about three inches too long.
RJC#512
post #36233 of 40700 Old 04-01-2014, 11:14 PM
Xpress
"JKS quick discos"
Thinking I might fit an anti-rock up front on mine...
Thoughts?
Xpress is offline
post #36234 of 40700 Old 04-01-2014, 11:16 PM
RikRotorhead
"JKS quick discos"
Oh... That.
I never go on my profile any more. Thanks for pointing that out.
RJC#512
post #36235 of 40700 Old 04-01-2014, 11:27 PM
Climbit
Thoughts?
you don't need it.
Climbit is offline
post #36236 of 40700 Old 04-01-2014, 11:32 PM
Xpress
Shutup you have a Cherokee
Xpress is offline
post #36237 of 40700 Old 04-01-2014, 11:35 PM
Climbit
you still don't need antirock...
get some coil springs first... then you can think about sway bars.
Climbit is offline
post #36238 of 40700 Old 04-01-2014, 11:41 PM
Xpress
Eh I like mine in place.... Extra peace of mind...
Xpress is offline
post #36239 of 40700 Old 04-02-2014, 08:53 AM
Climbit
And that's fine. But you won't get any benefit out of antirock
Climbit is offline
post #36240 of 40700 Old 04-02-2014, 10:20 AM
Xpress
Are you running one?
Xpress is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
