San Diego Area - Page 2326 - JeepForum.com
 46Likes
post #34876 of 40686 Old 11-18-2013, 05:54 PM
jbolty
jbolty's Avatar
Up until a few months ago I was running old man emu springs and shocks.
After almost 5 years the springs were bent and sagged to the point of needing to be replaced. I went with BDS this time. Just about the same ride but they are a little taller so now the shocks are wrong and acting as a limiting strap for down travel.
I measured the distance mount-to-mount for the shocks with the jeep on jack stands and the axles hanging free.
My question is this. Is there any reason to have the shocks be longer than that? In other words if one tire is up and one down or some other situation where the springs can droop or be pushed down even lower? I know some guys take off the spring clamps and I assume that means a lower droop, but is there a downside to doing that?
jbolty is offline
post #34877 of 40686 Old 11-18-2013, 06:36 PM
Chris
Guy with jeep
Chris's Avatar
I have fewer clamps than most on mine and a few of them have twisted out a little and you know how I baby my rig.
Chris is offline
post #34878 of 40686 Old 11-18-2013, 06:38 PM
smcalpac
The only drawback so going to be what your drive shafts steering linkage and brake lines limit
I'm here because
my little girl
doesn't need her dad
on two wheels anymore!
Camoflauge, camoflauge, I disappear when I pull out of my garage!
PM me for LED light bars and HID off road lights
smcalpac is offline
post #34879 of 40686 Old 11-18-2013, 06:42 PM
brokenyoujoint
I would have to say that it's good practice to give the shock more extension than your suspension gives. Even at an inch. You don't want your shocks bottoming out 1st. Same with compression. Give it about an inch minimum. Limit the movement up and down by bumpstops and either limit straps or your leafs. Just get some reservoirs and be done....
brokenyoujoint is online now
post #34880 of 40686 Old 11-18-2013, 06:45 PM
Climbit
yes. if your shocks are mounted outboard of the springs, articulation will mean more shock travel is necessary.
a good way to set it up is about 1" of shock shaft showing with both sides of the axle at full bump, and 1" left with both sides at full droop.
I have spent countless hours measuring my shocks at full bump/droop to maximize travel and that is how it has worked out for me.
Climbit is online now
post #34881 of 40686 Old 11-18-2013, 07:29 PM
premo
what they said. i wouldnt take off the clamps on your shocks, thats bad news. i have some limit straps in the garage you can have too if you want.
I finally got a locker, and its in transit. hope to pick it up along with my gears on Friday so i can get my junk back on the trail. hopefully we can thrash up my body beyond repair this season so i have an excuse to chop the top and cage.
-Scottish proverb
premo is offline
post #34882 of 40686 Old 11-18-2013, 07:35 PM
jbolty
jbolty's Avatar
Right now the rears have about 1/2 of extra down travel. The front was nearly 2" too short
Apparently they are called rebound clips and the primary purpose is to prevent "fanning" , or the ends twisting out of alignment side to side. Seems like the clip could be removed on one end but I guess I'll leave them alone for now.
jbolty is offline
post #34883 of 40686 Old 11-18-2013, 07:55 PM
Rrw600
You mean you want to add some beauty marks like Climbit did this weekend?
Rrw600 is offline
post #34884 of 40686 Old 11-18-2013, 08:26 PM
brokenyoujoint
Drooling until next yr......... 6" Genright stretch and this bad boy are on my To do list:
post #34885 of 40686 Old 11-18-2013, 11:12 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Easy stuff.
Joe Dillard is offline
post #34886 of 40686 Old 11-18-2013, 11:19 PM
Xpress
All about that unibody life.
Xpress is offline
post #34887 of 40686 Old 11-19-2013, 12:29 AM
Y0ungGunZJ
Originally Posted by Xpress View Post
Xpress those are coil Springs you hate those remember....?
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #34888 of 40686 Old 11-19-2013, 12:45 AM
aw12345
Easy stuff.
So there Kevin, now you know who to call
aw12345 is offline
post #34889 of 40686 Old 11-19-2013, 02:00 AM
Climbit
pshhhh
post #34890 of 40686 Old 11-19-2013, 07:51 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
As long as you understand that an off the shelf 6" stretch won't give you 6" more wheelbase than what it was stock, you're golden.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
