San Diego Area - Page 2314 - JeepForum.com
 61Likes
post #34696 of 40911 Old 10-31-2013, 10:48 AM
jbolty
jbolty's Avatar
Originally Posted by Motorep View Post
Man that sucks Jeff I was always concerned with damage to the R&P and locker with 30 spline or chromoly shafts. Seems if you get twisted up that force has to go somewhere and I'd rather blow stock axle shafts/u-joints than something in the diff. They're easy enough to swap out on the trail and used ones are had cheap enough to keep a few as spares.
Having ready access to spares is one reason I stuck with 27 spline.
Mark (progear) said he has general used chromo inner shafts and stock outers. There are pros and cons to using the "fuse" theory but no matter how you build some one thing has to be the weakest part. To me it seems better if it's cheap one.
jbolty is offline
post #34697 of 40911 Old 10-31-2013, 10:55 AM
Climbit
Was he able to diagnose what failed?
Climbit is offline
post #34698 of 40911 Old 10-31-2013, 10:59 AM
Climbit
Originally Posted by sdmoose429
Good to hear, Jeff. Wise choice. Does that mean you can go to the Melanoma run with me next weekend?
The run is in 2 weeks, not next weekend.
Climbit is offline
post #34699 of 40911 Old 10-31-2013, 11:05 AM
brokenyoujoint
the driver
brokenyoujoint is offline
post #34700 of 40911 Old 10-31-2013, 11:13 AM
jbolty
jbolty's Avatar
Originally Posted by brokenyoujoint View Post
the driver
I blame the spotter.
jbolty is offline
post #34701 of 40911 Old 10-31-2013, 11:18 AM
brokenyoujoint
If i recall, it went out when you were driving AWAY from that lil obstacle. You were basically on a simple itty bitty wash climb so if you needed a spotter for that, it was the driver...
post #34702 of 40911 Old 10-31-2013, 11:20 AM
jbolty
jbolty's Avatar
There was a shopping cart in my way.
jbolty is offline
post #34703 of 40911 Old 10-31-2013, 11:21 AM
brokenyoujoint
LMAO . That was a good one. bt, if your ARB failed before it blew out your ring/pinion which I dont really see how, you might wanna get the housing trussed. Thin walled dana 30's and crazy strong ARB's dont mix well. Thats why my ARB started walking out. I lost my preload. Get one of those sexy Arctec trusses. That way you can also glue some tuperware to the top of it to store a solenoid or something.. Think of the possibilities
post #34704 of 40911 Old 10-31-2013, 11:24 AM
jbolty
jbolty's Avatar
Anyone have any front shocks laying around I can use? I don't want to get into swapping towers or some other fancy mods; maybe next year.
With the axle hanging the distance ,mount to mount, is just shy of 28" The distance to the bump stop is 9 1/2 so I need about 10" of travel.
The old shocks were acting as limiting straps. The axle dropped about 2 1/2 inches further with them off.
jbolty is offline
post #34705 of 40911 Old 10-31-2013, 11:27 AM
brokenyoujoint
get some bilstein's... GREAT SHOCKS
post #34706 of 40911 Old 10-31-2013, 11:28 AM
premo
I concur. I love mine. Great bang for buck
-Scottish proverb
premo is offline
post #34707 of 40911 Old 10-31-2013, 11:30 AM
brokenyoujoint
jeep you might want the bilstein 4600's or the 5100's. the 4600's are the yellow ones , the 5100's are the silver ones. I run 5100's in my rear and have for about 10 yrs + . The only thing yellow I've ever had in my jeep was an asian chick.. Those were the days...
post #34708 of 40911 Old 10-31-2013, 11:31 AM
Climbit
If I had to buy again I would get fox 2.0s from savvy
Climbit is offline
post #34709 of 40911 Old 10-31-2013, 11:47 AM
brokenyoujoint
for the 30 bucks more, I agree.... but then jeff's jeep would ride like a tj and he wouldnt know what to do with himself. He might even pull off the door cushions.
post #34710 of 40911 Old 10-31-2013, 12:51 PM
Xpress
why would you rebuilt an engine just because the water pump went out? Did you drive it another 5 miles with no water in it and temps were pegged? Was the pump just leaking through the weap hole? Details please.
Water pump blew up, I assume the bearing inside of it let go, the fan wobbled around and took a chunk out of the top of the radiator shroud. I am hoping the radiator made it out without damage...
Serpentine belt of course got tossed out of place when that happened, only drove it about a mile with no water pump, and the engine was cold (half of that was with the engine off to keep from draining my brand new battery). The thing has 188K miles on it, so I'm wondering if it will be fine for a long time with just replacing some parts here and there, or if I should just go through and rebuild the entire thing and not worry about it.
All about that unibody life.
Xpress is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
