San Diego Area - Page 2195 - JeepForum.com
 61Likes
post #32911 of 40911 Old 06-30-2013, 07:47 PM
RikRotorhead
How's your back Chris? You have to work tomorrow?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #32912 of 40911 Old 06-30-2013, 07:50 PM
krughzn
Thanks - its coming along slowly but surely.
Figuring that you work 6 days a week and spent your only day off in your garage, I'd say it's coming along rather quickly. Looks really good, Joe.
krughzn is offline
post #32913 of 40911 Old 06-30-2013, 09:42 PM
Chris
Guy with jeep
Chris's Avatar
Still hurtin, not paying work but forming my RV pad and pouring three trucks of concrete on Tuesday.
Chris is offline
post #32914 of 40911 Old 06-30-2013, 09:49 PM
smcalpac
Mmmm, three trucks of concrete. Sounds like a wonderful start to my backyard.... All in due time I guess.
I'm here because
my little girl
doesn't need her dad
on two wheels anymore!
Camoflauge, camoflauge, I disappear when I pull out of my garage!
PM me for LED light bars and HID off road lights
smcalpac is offline
post #32915 of 40911 Old 06-30-2013, 10:33 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by brokenujoint View Post
But my question is still there.. What would/do you run for air? BTW, I have a detroit in the rear and I accept the fact that it pops, snaps, crackles and pops. That would be a silly denial really.
Here you go. I figured I'd start collecting these and send them your way since they are so simple for newbies to work on. You can walk them through it when you're bored.
http://www.wranglerforum.com/f5/need...up-252809.html
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #32916 of 40911 Old 06-30-2013, 11:21 PM
Chris
Guy with jeep
Chris's Avatar
Let me know when, I have friends in low places.
Chris is offline
post #32917 of 40911 Old 06-30-2013, 11:27 PM
smcalpac
Will do, I have friends and former family in low places as well but it never guest to have more!
I'm here because
my little girl
smcalpac is offline
post #32918 of 40911 Old 06-30-2013, 11:31 PM
TJRoberto
you can get a york210 at the yard.. make sure its a 210.. Early 80's wagoneers, 80's volvo's and mercedes cars have them to. Make sure you get one with a double V clutch fan. Dont cut the wires on them to close as you'll have to crimp onto them. You will have to buy a few things from KillMe.. I mean Kilby.. Alternator pulley for one.... If you need the solenoid or switches for the ARB I have a brand spanking still in the box set I'll $ ya cheap. Wiring is easy for the ARB, wiring for the York is even easier. Get two gauges, one for the ARB one for the accessories, some rubber air line hose, a belt, some fittings, a 2.5 gallon tank and your done.... oh and fab the mount bracket.. or buy one for 100.00 (yikes)....
Originally Posted by jbolty View Post
A York in a TJ is a whole different animal than in a YJ. It's not rocket surgery but there are brackets, valves, hoses, pressure switches and assorted bits and pieces. It can run into easy $200 without much trouble. I was lucky enough to find a compressor and bracket in an AMC Pacer with the same 4.2 engine so the bracket and everything dropped right in. I probably have $80 in mine .
Good luck, it will be the most expensive "cheap" mod you've ever done and that's if you don't count your time.
I wouldn't run that crap if you gave me all the parts, promised a perfect trouble free showroom quality installation for free, and then offered to swing by the trail or camp every time it had a problem.
Thanks for the advice guys, I originally was looking into getting a CO2 kit to activate the lockers. There are tons of people running York systems so it seemed like a better idea to do so since there would be more people to take advice from when trouble shooting and installing one.
But I do like the idea of simplicity and a trouble free set up of a CO2 kit. I just have not found a good enough write up where I can learn the basics on setting up a kit where I can run lockers & fill up tires. (I don't care about power tools)
TJRoberto is offline
post #32919 of 40911 Old 06-30-2013, 11:46 PM
Climbit
roberto, just get an ARB compressor to run the lockers. you want that system separate.
Climbit is offline
post #32920 of 40911 Old 07-01-2013, 08:22 AM
brokenujoint
you still dwelling on that? I thought you'd of moved on by now... And yeh, I went on there and gave hommie some advice.. We are all noobs at something... EVEN YOU.
If @ 1st you don't succeed, grind it, hammer it, weld it, drink a beer and try again.
brokenujoint is offline
post #32921 of 40911 Old 07-01-2013, 08:26 AM
brokenujoint
You could just do an ARB compressor as mentioned but try to find it cheap. They are EXPENSIVE for what you get.. When I had my ARB put in like 12 yrs ago that compressor (and maybe they are better now) SUCKED A55!! If your gonna go that route just get a Viaar compressor.. Dont really care what anyone says, I love my york set up.
post #32922 of 40911 Old 07-01-2013, 09:13 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You want your locker activation run by a stand alone system that is not used for anything else. Get the small ARB compressor. I have been patient over the last couple of years and picked up 3 of them at different times that are 75 bucks and they come with the harness, 1 switch, pressure switch, and mounting hardware, NIB.
Regardless of the haters, my ARB compressor in the crawler has been in use since 99 and has never had an issue that I didn't cause.
Even if you pay full pop they are generally available for 150 or so. Once you install it and marvel at the very nice plug and play aspect of the system, you will figure out real quick that it is money well spent.
The wiring on the new ones is stupid simple. 12v hot, 12 volt ground, interior light tap, and the rest is plugs that you plug together.
I am Savvy
post #32923 of 40911 Old 07-01-2013, 09:14 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm a newbie at a lot of things, compressed air ain't one of them though.
I am Savvy
post #32924 of 40911 Old 07-01-2013, 10:04 AM
TJRoberto
Thanks Blaine, brokenujoint & Climbit for the advise I'll go ahead and look for a compressor to activate only the lockers.
Just to clarify, my intention was to get a simple advice on what was the best source to activate a locker with. I never wanted to start an argument threat on what is better a York, ARB compressor or CO2 kit
But again I have only been in the wheeling community for 3 years and I still consider my self a noob. Compared to you guys that have 8+ years wheeling.
Thanks for advice!
post #32925 of 40911 Old 07-01-2013, 10:16 AM
smcalpac
It's not the years, it's the mileage that counts!
I'm here because
my little girl
smcalpac is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
