San Diego Area - Page 2091 - JeepForum.com
 49Likes
post #31351 of 40801 Old 04-12-2013, 09:13 PM
joeyk803c
Broken adjuster cable in the passenger side drum of the Dana35. :/ If it ain't one thing, its another! Wrenching party soon? I need to get this fricken' 8.8 installed.
On a side not, I'm looking for either a LP or HP30 to swap into the front of the TJ. Need one with 3.73 gears to match the 8.8. Have stuff to trade, maybe buy depending on how much.
joeyk803c is offline
post #31352 of 40801 Old 04-12-2013, 09:30 PM
krughzn
krughzn's Avatar
Originally Posted by TJRoberto View Post
Are you guys doing a day run or half day?
We should be done by 2. We're eating lunch at the top then will head down. If you can't make it tomorrow, next Saturday we're going to Truckhaven.
krughzn is offline
post #31353 of 40801 Old 04-12-2013, 09:34 PM
brokenujoint
Those brakes aren't crappy your set up is just to bad A55 . I forgot to give you the air fitting that goes onto the housing for the ARB line if you still want it. Not a biggie to get a new one but its here/it's free.. Whats up w/your buddy wanting that 4.56 pinion gear for the ring gear you have from me?
If @ 1st you don't succeed, grind it, hammer it, weld it, drink a beer and try again.
brokenujoint is offline
post #31354 of 40801 Old 04-12-2013, 09:34 PM
Xpress
Originally Posted by brokenujoint View Post
Xpress, Ive noticed your trend of asking a question, once you get an opinion (probably against what your leaning towards) you back pedal with defense instead of keeping an open mind
Re-analyze what I asked. I asked if I should invest in a 4:1 kit for the NP231, I didn't ask if I should keep the 231 or go with something else.
Stay ontopic and stop mis-quoting me.
All about that unibody life.
Xpress is offline
post #31355 of 40801 Old 04-12-2013, 10:21 PM
brokenujoint
ok , let me give ya the readers digest version. NO. I apologize for running off on a tangent. I guess the point was: If you stick w/the 231 dont throw to much money at it. ie the tera low... For the money saved its 1/2 way to a much stronger unit. Thats all i was getting at..
post #31356 of 40801 Old 04-12-2013, 10:32 PM
Chris
Guy with jeep
Chris's Avatar
I agree there are better options for a Tcase but I think a 231 is fine unless you like to abuse it in how you drive. I have one behind my 5.9 which sounds crazy but with only 40 HP more then the 4.0 I don't worry all that much. As for sinking a but load of money into one I would upgrade before I did that. Dodge Ram 2500 came factory with a 241 which is what I have for mine if I ever get around to swapping out the input shaft and they are both 23 spline and interchange.
Chris is offline
post #31357 of 40801 Old 04-12-2013, 11:21 PM
brokenujoint
a 5.9 only has 230 rwhp? really? Why the swap then. tq rates cant be much more then either??
post #31358 of 40801 Old 04-12-2013, 11:26 PM
Chris
Guy with jeep
Chris's Avatar
Somewhere right around 220-240 HP depending on where you get your info. It's really not that much greater but it is stil a V8 and sounds cool. I did it because I had the donor vehicle and wanted fuel injection.
Chris is offline
post #31359 of 40801 Old 04-12-2013, 11:27 PM
Chris
Guy with jeep
Chris's Avatar
Engine Type
360 cid 90' V-8 OHV
[1997 Curves]
1994-1997 Engine Serial Number
X M 5.2L T YYYY XXXXXXXX
X=last digit of model year
M= Plant - Mound road
S- Saltillo
T - Trenton
K - Toluca
5.9L=engine displacement
T=usage (truck)
YYYY=Month/Day
XXXXXXXX=8 digit serial no
2000-2001 Engine S/N
X M 318 YYYY XXXX
S- Saltillo
T - Trenton
K - Toluca
360=engine displacement (CID)
YYYY= Month/Day
XXXX=Engine Serial Code
Bore & Stroke
4.00 x 3.58 in. (101.6 x 90.9 mm.)
Displacement
360 cu.in. (5.9 L)
Compression Ratio
9.1 :1
Horsepower
245 hp @4000 rpm
Torque
330 ft. lbs. (448 N.m) @ 3250 rpm
Firing Order
1-8-4-3-6-5-7-2
Lubrication
Pressure Feed - Full Flow Filtration
Engine Oil Capacity
5.0 Qts. (4.7 L) with Filter
Cooling System
Liquid Cooled - Forced Circulation
Cooling Capacity
15.5 Qts. (14.7 L)
Cylinder Block
Cast Iron
Crankshaft
Nodular Cast Iron
Cylinder Head
Cast Iron
Combustion Cambers
Wedge - High Swirl Valve Shrouding
Camshaft
Nodular Cast Iron
Throttle Body Bore 50 mm
Chris is offline
post #31360 of 40801 Old 04-12-2013, 11:32 PM
Chris
Guy with jeep
Chris's Avatar
I am on 37's and 4:10's and my jeep is slower then when it had the 4.2 and 33's with 3:55's
Chris is offline
post #31361 of 40801 Old 04-13-2013, 12:20 AM
Xpress
I'm not building for all out speed. I've got it and unless I can fetch a pretty good chunk of change for it, I might as well use it. A 241 can always come later down the line.
And I don't have a lead foot
Xpress is offline
post #31362 of 40801 Old 04-13-2013, 12:28 AM
brokenujoint
Wow, this is a trip. I was building a 4.0 into a 4.6 stroker at 288 hp but gave it up because i realized after i had the whole thing put together that i didnt deck the block to zero and it would kill the quench. sold it for what it was worth and didnt lose much but now i'm considering doing it again. I wanted a 5.9 but those numbers seem discouraging for all the work and money. Are post 97 motors any different in result at the wheel? And at the 9:1 CR are you using a higher than 87 octane? My stroker was blueprinted to be at 8:8 , stock cam, cj 258 12 wt crank ,
post #31363 of 40801 Old 04-13-2013, 01:12 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Joe Dillard is offline
post #31364 of 40801 Old 04-13-2013, 02:36 AM
Climbit
nice!!!!
got an axle to go with dem 39s?
Climbit is offline
post #31365 of 40801 Old 04-13-2013, 07:13 AM
Joe Dillard
Originally Posted by Climbit View Post
nice!!!!
Still searching. Seems each axle I do see that's close to what I want, the CL poster is a complete flake & does not respond.
EG: I found a FF 14B in Mennifee, called and left messages with the knucklehead 3 times and texted twice. No response, even after he reposted the ad twice. This has happened 3 times so far.
Probably should have snatched up that D70 HD that was for sale in Jamul.
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
