San Diego Area - Page 2007 - JeepForum.com
 61Likes
post #30091 of 40911 Old 01-06-2013, 01:22 PM
Xpress
So who's all going to Joe's Jeep cave today? I get off work at 5ish, if anyone is still around then I might swing by for a bit...
All about that unibody life.
Xpress is offline
post #30092 of 40911 Old 01-06-2013, 02:42 PM
aw12345
I want to do a custom tummy tuck. One that uses a crossmember to support the tranny & allows the Atlas to sit nice & high. I have a 1" BL & 1" MML right now which should help a little. I don't mind beating/cutting on the tub so that the tcase doesn't bang against the tub when the frame flexes or when engine torque occurs. It doesn't have to be 100% flat, but as close as possible would be sweet. This needs to be done prior to 4link work to minimize suspension rework.
The fuel tank needs to be pulled and the Genright 23 gallon tub style fuel cell be mounted and all the lines ran.
The 8.8 needs to be pulled & a RuffStuff truss added, along with cutting off the current SOA traction bar bracketry. In conjunction with that - I want to stretch the rear wheelbase ~10" and have the truss welded accordingly. This needs to be done to account for going with a rear coilover upper triangulated 4link.
Cut the old rear leaf spring stuff off & prep the frame for the RuffStuff 4link axle install brackets.
Once the wheelbase is set & the links are made, get bumpstops installed and limit straps. The bumpstops may need to be frenched into the frame.
More than likely, install a rear antirock.
Going coilover with a narrow 8.8 is going to present some challenges of its own. Its a bit wider than a normal Explorer style 8.8 due to having a prototype Super 88 kit installed courtesy of Blaine. I have added 2" wheel spacer adapters as well so that the 8.8 has a 8x6.5 WBP to match the 60 front. These adapters may help a little to keep the tires out of the coils and further away from the towers.
At some point - add hydro assist.
That's the short list.
Today, I'm doing some front end bracketry welding and some touch-up stuff on the front axle and steering.
That's all piece of cake. Figure out your wheel base and what length arms you want and that will pretty much decide where the crossmembers end up.
Play with 4 link calculator and built it. Not anywhere near as hard as it looks
aw12345 is offline
post #30093 of 40911 Old 01-06-2013, 07:16 PM
jbolty
jbolty's Avatar
Funny thing is none of it's really hard but time sure does slip away. I started out today to replace the battery in my jeep and in the camper. Costsco on Morenoa didn't have them, but Mission Valley did; went there and they didn't have either. Went to Kragen and they had both batteries but the terminals on the camper one were on the opposite side; easy. Or not, the cable was about 3 inches too short. Go get a new cable, crawl under and swap it, then the battery then the jeep battery. It was almost dark by the time I got done.
Seems like every project goes that way. Or even worse, half way through think of a better way to do something or realize another job has to be done first.
I'm glad this is a hobby. If it was a job I would demand a raise or quit.
jbolty is offline
post #30094 of 40911 Old 01-06-2013, 07:28 PM
brokenujoint
60% google research and calls and 5% driving at best, and 35% online purchasing. I'm over driving blindly and aimlessly just so some schmoo can lead me to some other pointless destination. Jeff you should of seen me trying to pull 16 RE torq bolts that hold on my LA skid. I must of went to literally 20 stores and broke 6 sockets until I figured the solution. And when you do all this driving is it me or is there some Bruce Almightly looking down at you giving you EVERY red light?
If @ 1st you don't succeed, grind it, hammer it, weld it, drink a beer and try again.
brokenujoint is offline
post #30095 of 40911 Old 01-06-2013, 08:19 PM
joeyk803c
I'm lucky, I have 2 part stores within a mile of my house. And I work at Sears. Though I do know how such a simple project could have so many problems. Been there too many times.
joeyk803c is offline
post #30096 of 40911 Old 01-06-2013, 11:20 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Thanks go out to Taylor, Mike & Andy for stopping by and lending there hands.
We did some trimming of the front two body mounts, and made some weld-on reinforcement brackets for the outboard spring hangers. Then took the steering links & hysteer arms off, cleaned them up, drilled the arms and knuckles, painted them & re-installed everything. I did some touch up painting as well to the spring plates and mounts.
All in all a productive fun day. Thanks again guys.
Joe Dillard is offline
post #30097 of 40911 Old 01-06-2013, 11:31 PM
Joe Dillard
That's all piece of cake. Figure out your wheel base and what length arms you want and that will pretty much decide where the crossmembers end up. Play with 4 link calculator and built it. Not anywhere near as hard as it looks
Perhaps I need to give it a try & when I screw something up, or run into something I can't figure out, cry/beg for help.
post #30098 of 40911 Old 01-07-2013, 12:03 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Jeez all I did was break your drill bit and drink your beer.
How did it turn out? I know one of you had to take some pictures.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #30099 of 40911 Old 01-07-2013, 12:29 AM
Climbit
I took nothing!
Climbit is offline
post #30100 of 40911 Old 01-07-2013, 12:29 AM
aw12345
Isn't that what friends are for
aw12345 is offline
post #30101 of 40911 Old 01-07-2013, 08:40 AM
brokenujoint
with out pictures, it's just a myth
post #30102 of 40911 Old 01-07-2013, 09:09 AM
jbolty
jbolty's Avatar
I know, it's crazy.
You could start a complete frame off rebuilt, have every part on hand, all the tools, help and plenty of beer then the morning you begin the most simple thing runs the whole thing off the rails. Forgot the charge the battery for the sawzall, the extension cord is pinched under the jack stand, the shop light falls and breaks, etc. Then it's a mad scramble that kills the first 3 hours of the day.
jbolty is offline
post #30103 of 40911 Old 01-07-2013, 10:36 AM
WJDesertRacer
Originally Posted by jbolty View Post
I know, it's crazy.
I completely agree. I planned and prepared for the ttb swap for weeks and I still found myself every Saturday morning running around. It's always the little details that get you.
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #30104 of 40911 Old 01-07-2013, 11:26 AM
premo
Thanks Jeff for the help yesterday. finally got my winch installed. it only took like half a damn year LOL i have a Warn hawse fairlead brand new in teh box if anyone is interested. $40 bucks. please save me the drive to 4WP
next project is finish cutting/welding bumper stub ends and put LEDs back on. oh yea, and my beadlocks, and................ *sigh* it never ends.
-Scottish proverb
premo is offline
post #30105 of 40911 Old 01-07-2013, 03:39 PM
brokenujoint
What happened to me was I had to replace my clutch/flywheel due to a throwout bearing. So I order it online and wait a few days then while I'm waiting for it I go and start to pull everything apart. Plan the day for it. Dress crappy, gloves, glasses, radio, drink,etc. Get on my back, look at a crossmember bolt.. Hmmm T50 torx. Get up Find a T45, T55.. no T50. Of course. So I go buy one. Come back, turn out one of the RE skid bolts, (hard), then another, snap!!!! broke a 50torx socket.. #$#%$#@.. Go to the store buy another. Napa, nope, Autozone ? nope.. WTF! Oreilleys. yes... two please. try again. bolt wont budge.. Go to another bolt. comes off. another comes off. another.. STRIP. $$#@! This goes on for five T50 sockets at 8.00 a pop. After 3 wks of part time hatred I'm drilling these #%$$'s out then decide to weld bolts to them & turn them out. Dont have a welder. Price around. 100.00.. NO THANKS. Get on here and find a helping hand. Thanks WJDesertRacer. Also had to buy 50.00 worth of new bolts from RE (16 bolts) which took 2 wks to get. REALLY?!
All this took about 2 1/2 wks of being on my back drilling bolts out and breaking sockets and one breaker bar and cussing and throwing stuff..
When I finally got the bolt situation under control total price just to get these a-holes out was 110.00. (on a side note, I had a shop rebuilt my trans case about 7 yrs ago and they torqed the SNOT out of the bolts and didnt use antiseize . Thanks guys)
Drove the jeep back home. In 2.5 hrs I had the transmission out. Install? smooth except for forgetting to order up new flywheel bolts and that took 2 days. Had to order RoyalPurple online because no one sources them otherwise.
Clutch job from hell I tell ya's . From Hell.
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
