San Diego Area - Page 1985 - JeepForum.com
 50Likes
post #29761 of 40828 Old 12-10-2012, 11:33 AM
Speed-Freek
Using springs to provide damping is poor form. You need to get with Wayne at Alltech Motorsports and buy some tune time.
The springs were waaay to light for having a hardtop and rear seats and a cage. I put some 350# springs and have yet to try it, but it was more of a spring issue than the dampening, I have a shim set so I can play around with the comp. dampening. The front is pretty close, just needs a bit more dampening.
But I thank you for your input.
Originally Posted by Climbit View Post
pics or it never happened.
Yeah I have been threatening to take pics for about forever or so...OK, OK, OK, I will!!
ASE certified tech, and welder/fabricator for hire, PM me for any of your automotive needs!
Speed-Freek is offline
post #29762 of 40828 Old 12-10-2012, 11:43 AM
premo
Originally Posted by sdmoose429 View Post
Jason, Staying with the 31s for now. 4.56 gears and a 4 mouse motor go well with 31s. Drove it home from, the shop lst night and back this morning. WHAT A DIFFERENCE!! Now, when I step on the gas, it doesn't have to THINK about it. It just takes off. I get to use 5th gear now, as well.
I bet dude!
-Scottish proverb
premo is offline
post #29763 of 40828 Old 12-10-2012, 11:48 AM
Speed-Freek
Originally Posted by aw12345 View Post
How can the springs be to light if the Jeep sits higher then it was.
did you set up travel and droop at ride height before you even installed the springs? Once that's figured out you get the springs you want to get your ride height, then you start messing with the valving of the shocks.
King is a good choice since they let you swap springs when you first set the ride height. If you are bottoming out, you can try to adjust the dual rate sliders and from there you will have to delve into the shim stack in the coilovers.
Mr Wayne has a good name for setting this whole shebang up correctly
The only way I could get the height was by a sh!toad of spring preload. Not the proper way to get the height. I would love to be able to pay someone for help, but I have more time than money and the tools and ability (with less experience) so I will just play around with it till its right.
I made the shock mounts without the springs to figure out the proper travel, clearance, droop, and also to get the hydraulic bumps in the right place as well etc...I had the collars all the way down to get the primary spring to do work as soon as possible, so thats maxxed out already, telling me that my light spring is a bit light as well, so I am probably going to swap a stiffer spring from the front and put it in back while going up 50# on the upper spring in the front.
I already had Fox's that I pulled from my buggy before I sold it, and I tried to use a couple of the springs from it to save some money and I knew they were really on the lighter side before I installed them, I only did it to see how close I was after driving it the way I do.
Now at least I know where I need to be as far as spring rates go (or at least pretty darn close).
I have nitrogen, oil and shims, however I need to figure out where I can find some used springs, maybe I should check Pirate or Race Desert, I wonder if there is a spring exchange somewhere?? I know I cant be the only one with a bunch of extra springs he isnt using, and needs different ones. Or I may have to buck up and buy some new ones..
I have yet to try the new rear springs, I may have to go out to LW and give it a try and see how it feels before I know what needs to be done next.
But it waaay better than it has ever been for sure, work in progress as always.
post #29764 of 40828 Old 12-11-2012, 12:33 PM
premo
So I picked up a new pair of binoculars yesterday. Got the redfield rebel 10x42mm. Pretty stoked to try them out in the desert. havent had a semi-decent set in forever. Merry Christmas to me i guess lol
http://redfield.com/binoculars/
-Scottish proverb
premo is offline
post #29765 of 40828 Old 12-11-2012, 12:58 PM
jbolty
jbolty's Avatar
Thinking about a trip to Corral Canyon this weekend
Any interest and I'll make a thread about it.
jbolty is offline
post #29766 of 40828 Old 12-11-2012, 02:06 PM
Climbit
I might be able to do saturday... I'll let you know.
Climbit is offline
post #29767 of 40828 Old 12-11-2012, 02:14 PM
Climbit
I'm in for Saturday.
Climbit is offline
post #29768 of 40828 Old 12-11-2012, 02:33 PM
sdmoose429
Sunday is the ribbon-cutting/Grand Opening of the new trail off Gunslinger. TDS has invited everyone to come have food, and run the trail starting at 10 AM. Meet in the campground.
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline
post #29769 of 40828 Old 12-11-2012, 03:18 PM
jbolty
jbolty's Avatar
Hmmm. Might be fun, but on the other hand crowded.
I'm leaning toward saturday. I'll confirm tonight if I can make it one day or the other.
jbolty is offline
post #29770 of 40828 Old 12-11-2012, 03:46 PM
calsouthjeep
That new trail would be a disaster with a bunch of people running it especially because I bet a bunch of underbuilt guys are going to need to be dragged through it.
calsouthjeep is offline
post #29771 of 40828 Old 12-11-2012, 04:03 PM
jbolty
jbolty's Avatar
I would like to check it out for sure but I know the last new trail that opened had a bunch of manzanita stumps sticking up and there were flat tires about every 50 feet for the first year.
jbolty is offline
post #29772 of 40828 Old 12-11-2012, 06:14 PM
premo
Hey Rik!! i moved and dont have room in my garage for that massive california dreamin flourescent bar sign anymore...want that back? LOL Jeff, maybe for above the kegerator?
-Scottish proverb
premo is offline
post #29773 of 40828 Old 12-11-2012, 06:34 PM
WJDesertRacer
I've got a room full of street signs if it needs a home.
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #29774 of 40828 Old 12-11-2012, 06:42 PM
premo
ha! i had one of those a while back...that was a fun night lol
-Scottish proverb
premo is offline
post #29775 of 40828 Old 12-11-2012, 07:22 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Anyone in here know if these pads will work on a TJ? After a quick google it looks like the rotors will work, but couldn't find much on the pads. Pretty sure I bought them for my old TJ back in 2007, not too sure why I still have them
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
