San Diego Area - Page 1851 - JeepForum.com
 50Likes
post #27751 of 40828 Old 06-25-2012, 08:17 PM
Climbit
the quality is low, but you can see the T-Case in the upper left part of this video.
http://www.youtube.com/watch?v=78HSd...ature=youtu.be
Climbit is online now
post #27752 of 40828 Old 06-25-2012, 09:06 PM
MJ12
Climbt, do a google on mixing rubber with poly. I believe I had read that if you mix mounts you could potentially break something in your drive train. If I remember correctly, it happens during high torque moments on your drive train and the difference the rubber gives compared to the poly. My assumption is when everything is rubber or poly, they all move relatively the same, when mixed you have more twisting action taking place which could snap something. Of course I don't know if our 4.0 ever have a high hp or torque moment. Just somehting I believe I have read about, then again I might have been high off tequila and completely fabricated this. Check it with a quick google search...
Currently looking for:
-Leaf Springs that you want to get rid of.
MJ12 is offline
post #27753 of 40828 Old 06-25-2012, 09:27 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Where's the drop off?
Joe Dillard is online now
post #27754 of 40828 Old 06-25-2012, 09:41 PM
WJDesertRacer
Originally Posted by Climbit
if anyone wondered what Diablo Drop-off looks like from under my jeep, here you go.
http://www.youtube.com/watch?v=j1Vrw...ature=youtu.be
also, it was hot in anza-borrego today.
Looks good. What was the temp? With no a/c in my rig I gotta go at night. Going Friday actually.
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #27755 of 40828 Old 06-25-2012, 09:44 PM
Climbit
its there, my jeep just makes it look really small.
a little warm
nah, thats just my thermometer being baked in the sun... more like 105*-110*...but at least its a dry heat...
post #27756 of 40828 Old 06-25-2012, 09:52 PM
WJDesertRacer
That's what all desert people say. Haha and I agree.
<a href=
WJ dual sport</a>
post #27757 of 40828 Old 06-25-2012, 11:27 PM
StvDiego
It's the west end of trail that runs from the top of the Vallecito Creek mesa area to Fish Creek in Anza Borrego. It's the usual route to get back to the S2 after running the Pinyon Mt/Squeeze/Heart Attack Hill trail.
The actual Diablo Dropoff is just west of this trail and it truly is a drop off. The old road ended with no warning at about a 100+ foot drop, it's been closed since the last vehicle failed to stop at the top several years ago, ouch
Jeff running up Diablo Dropoff when his Jeep was cute
StvDiego is offline
post #27758 of 40828 Old 06-25-2012, 11:29 PM
calsouthjeep
What would I have to do to be able to swap in a Rubi case out of 08 into my 97?
calsouthjeep is offline
post #27759 of 40828 Old 06-25-2012, 11:33 PM
RikRotorhead
Originally Posted by Climbit View Post
stop being difficult rik. you are going to do a transmission and transfercase swap, and that is the end of the discussion.
OK dad.
If you aren't satisfied with the weld job, get in touch and I'll hunt down the feller I just helped with a trans to swap into his YJ to replace his BA trans. I don't know if it is a 10 or not, but I'll find out if you need it.
Thanks. I'll let you know. I don't know how long the bell housing has been cracked. I would prefer to replace it but welds are good if done right.
I miss driving my Jeep now that the weather is so good.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #27760 of 40828 Old 06-25-2012, 11:43 PM
DezertTJ
is it any different than a 03-06 rubi t-case? If not, then just the speedo and shift linkage would be it. My dad has an 05 rubi case in his. He used the Novak T-case cable and got the speedo to work with the supplied stock wires
DezertTJ is offline
post #27761 of 40828 Old 06-25-2012, 11:48 PM
calsouthjeep
Thats what I'm trying to figure out. The Jk forum on here is confusing
What year does he have?
post #27762 of 40828 Old 06-25-2012, 11:57 PM
DezertTJ
He's got a 97 TJ with the 4.0 and AX-15. The t-case is out of an 05 Rubicon. Since the JK uses wheel speed sensors, you wont have a speedo. It will bolt up though. You're better off getting a TJ rubi tcase
DezertTJ is offline
post #27763 of 40828 Old 06-26-2012, 12:10 AM
calsouthjeep
Yea I just say the speedo problem which would to a code being thrown. That would lead to check engine light and not being able to pass smog Im sure its correctable with some aftermarket gizmo but sounds like more money than it is worth
post #27764 of 40828 Old 06-26-2012, 12:39 AM
Climbit
as far as I know, the JK T-cases do not have a speedo sensor, they use wheel speed sensors.
post #27765 of 40828 Old 06-26-2012, 07:35 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm interested in knowing what that gizmo would be? Without a VSS output from the t-case, where else would you get it on a TJ?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
