San Diego Area - Page 1809 - JeepForum.com
 46Likes
post #27121 of 40691 Old 05-02-2012, 09:47 AM
jbolty
jbolty's Avatar
I've been using the 75-140 from walmart. When I first had my motor rebuilt I start babying it with fancy oil but since then I've switched to using cheaper stuff and changing it a lot. There seems to always be some reason for taking off a diff cover or swapping axles so it's always pretty clean. Same with motor oil. I probably change mine after ever 3-4 desert trips and it's pretty black, even though it's only probably been about 200 miles.
Clean oil is cheap insurance.
jbolty is offline
post #27122 of 40691 Old 05-02-2012, 11:30 AM
sdmoose429
Black oil is not THAT bad. Is it GRITTY? That is when you have issues. I've put oil in cars and had it turn black after 2 minutes of running. Some oils just do that. Of course there is also the school of thought that it is picking up dirt left behind from the last oil. This 'discussion' can go on forever. I have had long talks with petroleum engineers and I'm STILL not positive what is the right answer. Like Jeff says, "clean oil is cheap insurance".
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline
post #27123 of 40691 Old 05-02-2012, 11:38 AM
nuthead
Originally Posted by sdmoose429 View Post
SD 4 Wheelers Pancake Breakfast is that day. Moved from Pancake Rock to Corral Canyon.
Probably do Oriflamme/Rodriquez trails then to Mudcaves. Im not a big breakfast person unless its Bloody Marys!
Jeepers Creepers
nuthead is offline
post #27124 of 40691 Old 05-02-2012, 11:46 AM
jbolty
jbolty's Avatar
I'm sure the oil is chemically fine, but considering the talc like powder sand we run though I like to swap it often.
I'm thinking about adding an oil cooler and maybe a remote filter. I would like to get the filter up out of harms way since it hangs a little too close to rocks to suit me now. Plus if a motor mount fails the filter is done for.
jbolty is offline
post #27125 of 40691 Old 05-02-2012, 02:02 PM
premo
http://sandiego.craigslist.org/nsd/cto/2978752981.html
i need this thing, badly. someone please loan me money. or buy it and let me drive it on a run as a finders fee.
-Scottish proverb
premo is offline
post #27126 of 40691 Old 05-02-2012, 02:34 PM
DezertTJ
Wow thats different. Get it!
DezertTJ is offline
post #27127 of 40691 Old 05-02-2012, 02:55 PM
Rrw600
Say it isn't so. Junior Seau died this morning.
http://sports.yahoo.com/blogs/nfl-sh...182120394.html
He was an incredible player and class act. He will be sorely missed.
Rrw600 is offline
post #27128 of 40691 Old 05-02-2012, 03:22 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Yea, the sad news about Juniors death is spreading fast.
Joe Dillard is offline
post #27129 of 40691 Old 05-02-2012, 03:49 PM
premo
if i had the money laying around i'd swoop it up in a heartbeat. it would make an excellent, and safe, daily driver.
'MERICA!
-Scottish proverb
premo is offline
post #27130 of 40691 Old 05-02-2012, 05:00 PM
Climbit
that cage :barf:
Climbit is offline
post #27131 of 40691 Old 05-02-2012, 07:20 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I'm pretty sure that used to be a bolt.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #27132 of 40691 Old 05-02-2012, 07:29 PM
WJDesertRacer
can you take a right side front axle and flip it to be left side and high pinion, or will I have a front axle driving in reverse and a rear driving forward?
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #27133 of 40691 Old 05-02-2012, 07:40 PM
Xpress
If anyone has the ability to remove a rounded out harmonic balancer bolt, and can make a house call, great appreciation would be granted
All about that unibody life.
Xpress is offline
post #27134 of 40691 Old 05-02-2012, 10:24 PM
Climbit
weld a bolt to it (or have someone weld a bolt to it) and wrench it off
no, yes.
you need the same fix as andy (grewe02) weld (or have someone weld) a bolt to it, wrench it off.
Climbit is offline
post #27135 of 40691 Old 05-02-2012, 10:38 PM
MJ12
no, yes.
The welding idea tends to work the best on larger bolts but if you can't weld it, you could always drill a hole in the bolt, use pb blaster and an easy out on it....Marshalls Hardware will have everything you need to remove the bolt if you can't find it locally.
P.S. DON'T USE HARBOR FREIGHT EASY OUT'S..... They will make your problem worse....
Currently looking for:
-Leaf Springs that you want to get rid of.
MJ12 is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
