San Diego Area - Page 1804 - JeepForum.com
 47Likes
post #27046 of 40736 Old 04-24-2012, 10:37 PM
Speed-Freek
Originally Posted by calsouthjeep View Post
Just picked up Rubi 44's pumps and all for 2000. They looked super clean on the outside and when I cracked them open same thing. As long as the lockers and pumps work I think I got a steal.
Nice, should be a fairly straightforward swap, there are a bunch of good writeups on it as you probably know. What gear ratio?
Originally Posted by Climbit View Post
it runs fine. but if I am running around and it is hot, it occasionally stutters on re-start. I have had the code cleared twice to make sure its not something that easy.
I'd spend more time figuring it out and take care of it myself but I have to work all week.
Do you know what the code was before you cleared it? normally cam/crank sensors are a go/no go type deal in most cases, or sometimes the pickup gets too much debris on it to get a consistent reading and will have intermittent errors.
Do you notice any loss of power?
ASE certified tech, and welder/fabricator for hire, PM me for any of your automotive needs!
Speed-Freek is offline
post #27047 of 40736 Old 04-24-2012, 10:53 PM
calsouthjeep
The stock 4.11's which will be fine till I go to 35's which will still be awhile. I want everything set up right before I go there. As far as the swap, as long as there is no driveshaft length problems then it should be easy. Hows your setup coming along? Anyone progess on your suspension?
calsouthjeep is offline
post #27048 of 40736 Old 04-24-2012, 10:58 PM
StvDiego
I ran my old Rubi axles with 4:10 gears and 35's for a couple of years, worked fine, a little sloggish on highway uphills but not all that bad
StvDiego is offline
post #27049 of 40736 Old 04-24-2012, 11:16 PM
calsouthjeep
I think 4.10 on 35's would be pretty close, or maybe slightly better than 3.07 on 33's. To put it nicely the 33's/307 combo sucked for crawling especially climbing. I dont know whether I would eventually want 456 or 488. 456 seems like Id still be wanting deeper gears when crawling, where as 488 would be great for crawling but I'd have to be in third gear by the time I got through an intersection. I think the next steps are new CA's (savvy most likely but not sure whether to spend the extra for the aluminum?) and a steering upgrade (anyone going to ecology on the 5th or 6th).
post #27050 of 40736 Old 04-24-2012, 11:22 PM
Xpress
My starter died today when I tried to leave the house to get gas.
Tried to remove it and swap with a new one but one of the POS 6 point bolt heads stripped out, so now I'm out of a Jeep
All about that unibody life.
Xpress is offline
post #27051 of 40736 Old 04-25-2012, 07:49 AM
StvDiego
I have 4:88's now, work quite well but I do hit 3rd gear after 50 feet
Nice on the highway but max's out about 75
Will be at Ecology Saturday morning for the half-price sale to get more junk I don't need. Usually there's always a GC steering setup there (If you go grab two, carry a spare setup)
I have the Savvy aluminum uppers, they are nice for adjusting the pinion angle, but in reality, once it's set, it's set, it's not going anywhere. And the lock nuts are sort of a pita. You could get the standard arms and if the mood strikes you down the road you can always buy just the aluminum arm but my feeling is that the standard arms have been great for years and will continue to be great for years to come.
StvDiego is offline
post #27052 of 40736 Old 04-25-2012, 08:08 AM
calsouthjeep
By standard are you talking about the steel ones or you talking something without johny joints. When I price it out with just uppers and then another brand for the rest the price difference isn't great enough for me to go with something that will likely be replaced sooner than the jj's.
post #27053 of 40736 Old 04-25-2012, 08:12 AM
MJ12
Originally Posted by 00xj54 View Post
FREEEEEEE THIIIING
Hello all. I have a K & N cylinder air filter with a mount. I used this for my Cherokee with the 4.0 and now that I don't have a Jeep I'm giving this away to anyone who wants it.
Please e-mail me if your interested. markasimone@yahoo.com
Email Sent
MJ12 is offline
post #27054 of 40736 Old 04-25-2012, 08:58 AM
jbolty
jbolty's Avatar
Jeep swap meet in Temecula. 5/19.
http://www.myjeeprocks.com/forums/sh...-Meet-May-19th
jbolty is offline
post #27055 of 40736 Old 04-25-2012, 09:46 AM
sdmoose429
Originally Posted by Xpress View Post
Bolted in my new muffler yesterday, amazing how quiet these engines are when they have a good muffler on them
Also put in some new Pioneer 4" speakers into my soundbar. My old ones were rotted apart and had all but blown up, these new ones comfortably pump out sound where the old ones were screaming for mercy
So, the new muffler makes the speakers sound even better, right?
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline
post #27056 of 40736 Old 04-25-2012, 12:27 PM
TJRoberto
Originally Posted by jbolty
Why does the good stuff always happens on a Saturday
I need to get Saturdays and Sundays off
TJRoberto is offline
post #27057 of 40736 Old 04-25-2012, 09:22 PM
Xpress
Update: Had to spend $70 on a reman starter at AutoZone, was able to get the stripped out bolt off with an impact hammer. Threw the new starter in and it roared to life with ease.
No, my new speakers make my new music sound better
Xpress is offline
post #27058 of 40736 Old 04-25-2012, 10:09 PM
Climbit
its a 2.5...it didn't roar anywhere....
Climbit is offline
post #27059 of 40736 Old 04-25-2012, 11:33 PM
Xpress
You know nothing.
Xpress is offline
post #27060 of 40736 Old 04-25-2012, 11:56 PM
StvDiego
Correctomundo, steel as opposed to aluminum. The Currie arms are pretty sweet. Somewhere buried in JeepForum is a good set of directions from Blaine on setting up a Currie lift. Be sure to get the Currie bumpstops.. I'll poke around and see if I can find it
Spend money at swap meet or spend money wheeling and camping, hmm
After careful consideration, the desert wins
StvDiego is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
