San Diego Area - Page 1803 - JeepForum.com
 61Likes
post #27031 of 40918 Old 04-23-2012, 12:01 PM
sdmoose429
Like this?
Yes. Not that color though, and I didn't see if there was one on the hood.
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline
post #27032 of 40918 Old 04-23-2012, 12:07 PM
sdmoose429
Originally Posted by speed-freek View Post
dont use a gasket for the oilpan!! They will just eventually fail, i clean the block and oilpan surface really well using brake clean, then go get yourself some permatex "the right stuff!" comes in a aerosol can like cheese whiz, put a good bead on the pan and install, this way you have a permanent seal that will not ever fail.
I dont remember the last time i used a pan gasket, use the sealant where applicable is far better than any gaskets unless they are the aluminum/silicon type.
x2!
post #27033 of 40918 Old 04-23-2012, 01:17 PM
MJ12
Originally Posted by Speed-Freek View Post
Dont use a gasket for the oilpan!! They will just eventually fail, I clean the block and oilpan surface really well using brake clean, then go get yourself some Permatex "The right stuff!" comes in a aerosol can like cheese whiz, put a good bead on the pan and install, this way you have a permanent seal that will not ever fail.
I dont remember the last time I used a pan gasket, use the sealant where applicable is far better than any gaskets unless they are the aluminum/silicon type.
Thanks for the info. I actually have a two brand new cans of that, not sure why I did not think to use it. Any input on replacement oil pans? I know some times with different manuafactures your get variations where some fit better then others.
MJ12 is offline
post #27034 of 40918 Old 04-23-2012, 08:47 PM
04axeman
jason, any update fo a video this last weekend?
04axeman is offline
post #27035 of 40918 Old 04-23-2012, 09:07 PM
MJ12
No, I haven't really got around to it yet. Probably wont get to it till this weekend. I spent half the day yesterday chopping my trailer and re-welding it. Then I spent the rest of the day cleaning up after my grinding and reorganizing the garage so that I could fit the trailer on its side in my garage with the jeep.
MJ12 is offline
post #27036 of 40918 Old 04-23-2012, 11:21 PM
Climbit
pics or it never happened.
Climbit is offline
post #27037 of 40918 Old 04-23-2012, 11:47 PM
calsouthjeep
Just picked up Rubi 44's pumps and all for 2000. They looked super clean on the outside and when I cracked them open same thing. As long as the lockers and pumps work I think I got a steal.
calsouthjeep is offline
post #27038 of 40918 Old 04-24-2012, 12:13 AM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Bolt right in...
Now you need to find a NP241J
CRAWLING 98 is offline
post #27039 of 40918 Old 04-24-2012, 12:27 AM
Climbit
painted the skid today. and yes, I touched it up after it was under the jeep.
unfortunately, my CEL is back, its probably a crank or cam sensor. the key trick did not work to get me the code. and I am working the rest of the week, so the mechanic will have to take care of it.
BUT
I think I have saturday off. so I want to do a shakedown run... its been more than a year since I've wheeled, and I want to see how the skid does. I won't know until later this week if the CEL will be taken care of in time, but either this or next weekend I will be wheeling!
Climbit is offline
post #27040 of 40918 Old 04-24-2012, 01:02 AM
sdmoose429
BUT
Is it running ok? The CEL might just be a gas cap or something...wheel it anyway
post #27041 of 40918 Old 04-24-2012, 01:06 AM
Climbit
it runs fine. but if I am running around and it is hot, it occasionally stutters on re-start. I have had the code cleared twice to make sure its not something that easy.
I'd spend more time figuring it out and take care of it myself but I have to work all week.
Climbit is offline
post #27042 of 40918 Old 04-24-2012, 02:05 AM
MJ12
My brother in-law said the same thing. I'll post them in the morning....
MJ12 is offline
post #27043 of 40918 Old 04-24-2012, 02:10 AM
MJ12
I have a scanner that can also read live data and of course clear CES. You can borrow it as long you don't break it. :-) I work in point Loma and am home by 1600 every day. Just let me know if you want to use it.
MJ12 is offline
post #27044 of 40918 Old 04-24-2012, 09:48 AM
MJ12
Currently looking for:
-Leaf Springs that you want to get rid of.
MJ12 is offline
post #27045 of 40918 Old 04-24-2012, 10:38 AM
Xpress
Bolted in my new muffler yesterday, amazing how quiet these engines are when they have a good muffler on them
Also put in some new Pioneer 4" speakers into my soundbar. My old ones were rotted apart and had all but blown up, these new ones comfortably pump out sound where the old ones were screaming for mercy
All about that unibody life.
Xpress is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
