San Diego Area - Page 1802 - JeepForum.com
 47Likes
post #27016 of 40736 Old 04-21-2012, 01:34 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by sdmoose429 View Post
Just saw a canary yellow JK on I-15 N with a decal on the door that was interesting. It was the Biohazard symbol, (like Joe's avatar), and around it were the words, "Zombie Outbreak Response Team". COOL! My 1st thought, a cross between Joe Dillard and Rik Rotorhead. OMG
Like this?
Joe Dillard is offline
post #27017 of 40736 Old 04-21-2012, 08:57 PM
MJ12
Does anyone have any opinions on oil pan replacement and gaskets? Stick with dealer, specific aftermarket? Doesn't matter, they all fit the same? Same goes for the rear main seal, any input?
MJ12 is offline
post #27018 of 40736 Old 04-21-2012, 09:14 PM
RikRotorhead
I went wheeling the other day and when I came home I parked the Jeep in the garage.
I went to start it again and when it started it made a grinding sound coming from the flywheel.
I thought it might be a bad starter, the bendix wasn't returning and the gear was grinding on the flywheel.
So I took the starter out and returned it to Autozone because it has a lifetime warranty. Got a new one, put it in.
Same noise. Pulled the starter, no grind marks on the bendix gear.
Held the starter in place and had someone start the Jeep. When it started I pulled the starter away from the bell housing.
The noise was still there and I could see sparks in the bell housing. Shut the engine off right away.
So what I'm thinking is, maybe a bolt that holds the clutch plate on fell off or is loose and rubbing?
Anybody wanna' guess? I know I have to pull the tranny but I'm curious what you all might think it is.
I'll report back when I pull it as to what it is.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #27019 of 40736 Old 04-21-2012, 09:56 PM
Rrw600
Had a fun day wheel'n at CC with MJ12 and Matt & Justin. Here's a few pics.
IMG-20120421-00047.jpg   IMG-20120421-00054.jpg   IMG-20120421-00056.jpg   IMG-20120421-00050.jpg
Rrw600 is offline
post #27020 of 40736 Old 04-21-2012, 10:16 PM
krughzn
krughzn's Avatar
I spent a few hours over at Joe's today and watched him burn some metal on Taylor's skid plate. Then Taylor helped me put my battery sensor cable back in. Actually he did all the work and I watched and tried to lose some of Joe's tools. I wish I could of headed out to CC. That's always fun.
krughzn is offline
post #27021 of 40736 Old 04-21-2012, 10:22 PM
Rrw600
Yeah, it was a beautiful day out there. Not too hot yet. We ran Sidewinder, then Bronco Peak. If we'd have had more time, were going to try and squeeze in gunslinger to, but had to be back for my other son's piano recital.
Rrw600 is offline
post #27022 of 40736 Old 04-21-2012, 10:55 PM
jbolty
jbolty's Avatar
Can you maybe get in there with a long magnet through the starter opening or the inspection plate?
jbolty is offline
post #27023 of 40736 Old 04-22-2012, 12:15 AM
Climbit
some day you will be as strong as me, then you can plug your sensors back in
we will be finishing up the skid tomorrow.
progress!
Climbit is offline
post #27024 of 40736 Old 04-22-2012, 08:35 AM
Xpress
Not too jazzed about having to drive to work this morning
All about that unibody life.
Xpress is offline
post #27025 of 40736 Old 04-22-2012, 11:28 AM
RikRotorhead
Funny you mention that. I did try that. I have one of those HF magnets on a gooseneck and it just kept sticking to the flywheel.
I need one of those inspection cameras.
Either way I gotta' pull the trans I'll bet. It's not that hard of a project, just time consuming.
Too bad it doesn't need a new clutch.
RJC#512
post #27026 of 40736 Old 04-23-2012, 12:03 AM
Climbit
so Joe, Andy and I finished up my t-case skid today... it was pretty easy
NOT......
Climbit is offline
post #27027 of 40736 Old 04-23-2012, 08:11 AM
joeyk803c
My seats are SOAKED from last night dude. Whole interior is wet ftl.
joeyk803c is offline
post #27028 of 40736 Old 04-23-2012, 09:28 AM
Xpress
Mine is the same
Xpress is offline
post #27029 of 40736 Old 04-23-2012, 10:16 AM
Speed-Freek
Dont use a gasket for the oilpan!! They will just eventually fail, I clean the block and oilpan surface really well using brake clean, then go get yourself some Permatex "The right stuff!" comes in a aerosol can like cheese whiz, put a good bead on the pan and install, this way you have a permanent seal that will not ever fail.
I dont remember the last time I used a pan gasket, use the sealant where applicable is far better than any gaskets unless they are the aluminum/silicon type.
ASE certified tech, and welder/fabricator for hire, PM me for any of your automotive needs!
Speed-Freek is offline
post #27030 of 40736 Old 04-23-2012, 10:17 AM
Speed-Freek
NOT......
Looks great!
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
