San Diego Area - Page 1800 - JeepForum.com
 50Likes
post #26986 of 40827 Old 04-18-2012, 12:44 PM
TJRoberto
Originally Posted by GOWAD
hay man i have a trans siting here from my last setup you can have if you want for now till you fix yours it shifted smooth i just didn't have the tc lock hooked its a 32rh ....
and i know places close by here in Mexicali MX that do hell of a job with trans you just have to take it out of the jeep and we can just cross with just the transs to get it fix keep in mind i live in imperial ca 5MI away of superstition
so if you want my old trans you can have it
if you want my buddy's shop take your trans out and get it rebuilt in MX we can do that for you too for allot less than what that shop is telling you
Thanks for the help but if you are not sure about selling it I think I'll just have to bite the bullet and find another shop that will do the work cheap like you said in Mexico labor is way cheaper
TJRoberto is offline
post #26987 of 40827 Old 04-18-2012, 01:44 PM
GOWAD
um..... i was not trying to sell you anything ? only the gas money that you will be spending coming over here and back the trans is in westmorland that's about 105MI away from SD keep in mind it's a good trans but i dont feel good selling it to some one 1st i never hook up the locking TC so i don't know with that 20,000MI that it have on it it over heated or not also we changed the TC holes to match my old flywheel so that's why i was going to give it to you and it works shifts like a champ
GOWAD is offline
post #26988 of 40827 Old 04-18-2012, 03:36 PM
TJRoberto
Pm sent
post #26989 of 40827 Old 04-18-2012, 03:56 PM
sdmoose429
Originally Posted by premo View Post
have i ever told you guys about my experience at Midway Jeep when i went in for a quote for repair after i drove over that altima?? LOL
Yes.
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline
post #26990 of 40827 Old 04-18-2012, 04:00 PM
sdmoose429
Originally Posted by Gomez View Post
While we're on the topic or **** or shady service.
Had the infamous P0016 code thrown last week after a BL/MML. I knew there was a whole can of worms going on surrounding that code and issues with camshaft/OPDA gears in 05/06 models. While searching JF for what it could be I figured that maybe we hit the OPDA while putting in the MML and threw the timing off or possibly hit the sensor. Either way, the Jeep was running on "limp" mode and capping at 3500 RPMs due to the malfunctioning sensor.
The Jeep sounded fine and did not have any knocking, screaming, or any other unusual noises coming from the OPDA or any where else so I took it to the dealership (Rancho Chrysler off Balboa) to see if they could figure it out. They told me it was the cam and crank sensor and estimated it would be $85 for parts and $300 for R&R. I let out a laugh and told him to just order the parts and I'd do it myself. 20 minutes is all it took. Rounding to .5 labor units would put their shop at $600/labor unit. WTF? I did have to take it back to get the engine code cleared due to the sensors needing to be re-synced ($50).
I hate dealerships!
Me, too. What is OPDA? Haven't seen that one yet....
post #26991 of 40827 Old 04-18-2012, 04:02 PM
sdmoose429
This sounds like a good time to hit Superstition, too.
post #26992 of 40827 Old 04-18-2012, 05:01 PM
Gomez
OPDA = Oil pump drive assembly. There are a few hundred pages here on JF that go into detail about the issue. It's only for 05/06 model TJs.
Gomez is offline
post #26993 of 40827 Old 04-18-2012, 05:57 PM
TJRoberto
Thanks to GOWAD, for letting me have the 32rh tranny that he is not going to use. I'll be going to pick it up this weekend.
I called Sparkys to check how much he would charge to take out the burned tranny and replace it with GOWAD tranny and according to him the minimum charge is $600 with out anything else going wrong in the install
Im still undecided if I should go that rout.
After deciding to bring my jeep back to my parents house he said it was $75 for a joy ride and taking off the skid plate to inspect the oil pan of the tranny.
post #26994 of 40827 Old 04-18-2012, 09:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Did you figure out yet that buying the cheapest part you can find isn't always the smart way to go?
I'm not quite following the 32RH that sounds like it came out of the YJ, but if you can't hook up the Torque Convertor Lock-up circuit, you will need to get a manual trans PCM so you won't have a continual check engine light on.
If it does have the plug on the back of the trans, you need to make sure you use the right torque convertor that has the clutch plates in it that can lock up.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #26995 of 40827 Old 04-18-2012, 09:46 PM
TJRoberto
The tranny that is currently in my TJ it came out of a 98 TJ sahara, it does have the plug in the back of the tranny, and I used the original torque converter that came with the tranny
post #26996 of 40827 Old 04-19-2012, 07:58 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I understand that part and did from the start. The part that concerns me is the different trans you are going to use or are considering using.
Just make sure of the things I warned you about.
I am Savvy
mrblaine is offline
post #26997 of 40827 Old 04-19-2012, 09:00 AM
StvDiego
^^ In the FWIW category: I got a couple of things from this guy in Chula Vista yesterday, he has a couple of TJ's he is parting out while rebuilding his TJ, one was rolled (5-speed) the other was a flood recovery (auto). He also buys wrecked TJ's at the auction and parts them out. If you need a new ECM to make the other tranny work he may have one, he has a ton of parts sitting around:
http://sandiego.craigslist.org/ssd/pts/2958366929.html
StvDiego is offline
post #26998 of 40827 Old 04-19-2012, 10:46 AM
TJRoberto
Thanks for the heads up,
I called and he is only selling the 5speed
post #26999 of 40827 Old 04-19-2012, 11:55 AM
GOWAD
Robert the trans that i have i think its off of 95 yj or 94
GOWAD is offline
post #27000 of 40827 Old 04-19-2012, 08:24 PM
MJ12
Anyone want to go out on Saturday to CC or Pancake Rock? Right now it appears myself and two others will be going out, just have not totally decided on where we are going.
MJ12 is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
