San Diego Area - Page 1786 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > California Jeep Forum > SanDiego > San Diego Area
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 03-28-2012, 11:28 AM   #26776
sdmoose429
Originally Posted by jbolty View Post
Best thing to do is add a transmission temp gauge; heat is the #1 enemy of any auto trans.
Yeah, what he said.
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline   Reply With Quote
Unread 03-28-2012, 01:21 PM   #26777
Climbit
What's that? Bush's Foreign Policy?
You nonproofreaders crack me up.
quit trolling SD.......
thats my Job
When you do, put the sensor bung in the pan. The only temp you care about is how hot the transmission is.
want to put one in my aw-4 pan?
[URL="http://www.jeepforum.com/forum/f22/climbits-daily-driven-weekend-wheeling-affair-1191536/"]Build[/URL]
[CENTER]JF Recon member #43[/CENTER]
[COLOR="White"][CENTER]White Jeep Club Member 127[/CENTER]
[/COLOR]
[QUOTE=RikRotorhead;14565104]
I'll buy you a beer when I see you and we can kiss and make up. lol :cheers2:[/QUOTE]
[QUOTE=YJames90;14618050]I'm gay[/QUOTE]
Climbit is offline   Reply With Quote
Unread 03-28-2012, 02:30 PM   #26778
TJRoberto
Ill run it for a couple of weeks with the current aluminum radiator to get it on the road for now, cant wait to test that tranny out!!
Blaine do you install the parking cable in the steering column when you swap in the bezel cables for the tranny? another question did you have any issues with leaking oil in between the 32rh tranny and the 241TC on Mike's TJ (krughzn)?
TJRoberto is offline   Reply With Quote
Unread 03-28-2012, 08:33 PM   #26779
sdmoose429
thats my Job
Do you mean ME, Taylor?
Unread 03-28-2012, 09:29 PM   #26780
Climbit
I meant Blaine needs to stop trolling The SD thread....
It's my job
[/COLOR]
Unread 03-28-2012, 10:18 PM   #26781
mrblaine
mrblaine's Avatar
I haven't taken a manual column with the push to release key button apart far enough to find out if you can even put the brake release cable in there.
No, no oil leak between the two, but I installed the seal extension from Tera before we put the t-case in.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 03-28-2012, 10:22 PM   #26782
mrblaine
mrblaine's Avatar
thats my Job
I was trolling the big feller.
Sure, no problem and almost free. I only need the pan and the brass or steel sensor bung. I can permanently attach either to the pan with an application of high intensity localized thermal power to an appropriate filler material.
I am Savvy
Unread 03-28-2012, 11:17 PM   #26783
Rrw600
So, kind of bummer today. Went out to drive the jeep after it sitting in the garage for a couple of days and there were two cracks in the front windshield, about 2-3 inches down on each side of the windshield and about 5-6 inches long. WTH. How hard is it to replace the front winshield? Where's the best value to buy the windshield.
Rrw600 is offline   Reply With Quote
Unread 03-28-2012, 11:29 PM   #26784
Motorep
Motorep's Avatar
I see 'em on Craigslist almost daily.
"I remember when country music was George Jones and Dolly Parton," "Now it's the cast of 'Glee' with cowboy hats." -Ron White and his mother at the 2012 ACMA show
Motorep is offline   Reply With Quote
Unread 03-29-2012, 07:56 AM   #26785
TJRoberto
Okay I just wont worry about that parking cable at all.
is this the one ill need? http://www.teraflexplus.com/shop/aut...extension.html
Unread 03-29-2012, 08:07 AM   #26786
mrblaine
mrblaine's Avatar
Make sure the NSS works or you can get in a fair bit of trouble.
Yes, you will need that if you are using the 241 or the 231 from your manual transmission.
I am Savvy
Unread 03-29-2012, 08:15 AM   #26787
TJRoberto
Thanks so much for all those helpful tips Blaine
Hopefully in a couple of months ill take my TJ over to your place so you can outboard front/rear socks and relocated the rear spring. But first I want to install some highline fenders up front. and swap in a HP30 that I have at my buddies house.
what do you mean by NSS?
Unread 03-29-2012, 09:37 AM   #26788
sdmoose429
Neutral Safety Switch?
Unread 03-29-2012, 10:10 AM   #26789
mrblaine
mrblaine's Avatar
Neutral Safety Switch. On the last AW-4 swap, I was going to leave it undone with the owner's permission. Then I was doing some testing sitting in the driver's seat with both feet hanging out the door and it was in gear not neutral or park.
The battery was a bit low, so when I started it, the computer kicked it into high idle to charge the battery. I almost ran over some important bits in the driveway before I could swing my foot in and get it on the brake after popping it into neutral.
Hook up the NSS and make sure it works.
No worries on the outboarding. Just bring Steve with you. I'm particularly fond of his, "We'll do everything but the welding" method of getting this done.
I am Savvy
Unread 03-29-2012, 02:45 PM   #26790
Rrw600
TJR - are your feet cold? Maybe Blaine has some wool socks.
