San Diego Area - Page 1754 - JeepForum.com
 50Likes
post #26296 of 40828 Old 02-13-2012, 12:39 PM
Delta347
Originally Posted by Speed-Freek View Post
I didnt get the memo..
I wasnt sure how it would turn out, but I can probably make more in the future, I certainly have more aluminum...
I was going to see how this one turned out and maybe I will make others, but this sucker was labor intensive to say the least..
I was looking for a new skid plate since I completely destroyed my stock one, and I even beefed it up! So the new onoe will sit higher and hopefull be a little more tough, I may even add on some sort of slider to the bottom of the skid.
Hope it doesnt rain on me today!!
Soooo you could make more huh? Is this for the 20gallon YJ tank?
I need to buy or make a skid plate for my new 20gal tank. I'm upgrading since Im putting the 4.0L in. I was just going to buy one of the 180$ warrior brand ones that are diamond plated because I can't find any other ones besides JY ones.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #26297 of 40828 Old 02-13-2012, 12:47 PM
TJRoberto
Tell me about it I haven't been able to get started in my auto swap thanks to the crappy weather. I am dying to get my TJ out in the dirt, rocks, sand or even on the aslphalt I really need a garage.....
Its funny how some times my girls starts day dreaming a about the perfect house for us, bla bla bla bla... only thing that comes to my mind is a nice big garage where I can put my Jeep in side and work on in, with fridge to keep the beverages cold
TJRoberto is offline
post #26298 of 40828 Old 02-13-2012, 03:53 PM
92 Green YJ
92 Green YJ's Avatar
LMAO. I know the feeling. I have told the wife several times a 2 car garage is mandatory. If a house she likes doesn't have one, we wont be considering it.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #26299 of 40828 Old 02-13-2012, 05:20 PM
TJRoberto
Can you guys give an idea of where can i find:
1/8"-27 NPT male to 1/4" barb
I'm going to relocated the air vent in my 32rh tranny but i cant find the proper barb, I already have the 1/8"-27 NPT pipe thread tap, and 21/64" drill bit but homedepot does not have the barb
this in case you guys want to know what i need it for here it ishttp://www.jeepforum.com/forum/f9/relocating-vent-32rh-3-speed-auto-462033/
post #26300 of 40828 Old 02-13-2012, 06:35 PM
calsouthjeep
HELP. Everything has gone so dang smooth so far swapping the front axle except I'm stuck. How the heck do I unbolt the front uca's. they both have tabs that you can't put a wrench on but they done catch on anything either so they are spinning when I'm trying to unbolt it. If I had a welder id tack it on unbolt the nut and cut the tack but thats not an option cause i dont have a welder. How do I keep the tab from spinning
calsouthjeep is offline
post #26301 of 40828 Old 02-13-2012, 06:39 PM
Chris
Guy with jeep
Chris's Avatar
I ended up with a three car garage when I bought and wish I had a four now.
Chris is offline
post #26302 of 40828 Old 02-13-2012, 07:06 PM
WJDesertRacer
Marshalls Hardware off Production and Miramar Rd
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #26303 of 40828 Old 02-13-2012, 08:50 PM
MJ12
http://www.jeepforum.com/forum/f9/ho...-bolt-1170179/
MJ12 is offline
post #26304 of 40828 Old 02-13-2012, 09:07 PM
joeyk803c
For those who are doing/have done an Auto swap. What is the rough cost for doing the swap. I love driving stick, but I'm thinking about converting my TJ over to an auto.
joeyk803c is offline
post #26305 of 40828 Old 02-13-2012, 10:04 PM
StvDiego
2003 was the first year of the 42rle auto. Before that the TJ used the 32rh. The 42rle is much more computer dependent than the earlier auto, more wiring, more issues, not necessarily a good swap. You can install the earlier 32rh, or, if you're up for the adventure, the AW4 from an XJ, both are better choices, but require a good bit of work.
Plan on at least $500 in parts alone if you either get lucky or carefully shop and source the parts. A more realistic range is at least $750 - $1000. Personally, I'd spend the money on upgrades first
StvDiego is offline
post #26306 of 40828 Old 02-13-2012, 10:22 PM
TJRoberto
Thanks
StvDiego is dead on in the price, between $750 and $1000 i was lucky enough to grave a complete auto swap for $550 incluting;
-32rh tranny
-computer (ECM)
-Shifter Cables
-Break pedal
-shifter/bezel
-tranny hard coolant lines
-Torque converter
-tranny mount bracket
-shift cable bracket
- tranny mount
the only thing that I had to buy some place else was the flex plate and a cooler for the tranny. Just be in the look out to get a complete swap. good luck
post #26307 of 40828 Old 02-13-2012, 10:35 PM
joeyk803c
Thanks guys. I'm just kinda seeing what things cost, to get an idea on what I want to do first. I think I'll start working on fabricating some new bumpers/fenders, and go on from there.
post #26308 of 40828 Old 02-13-2012, 11:52 PM
Climbit
I realize this is really late notice, but my axle is going back in tomorrow morning.
if anyone is around 830am-whenever the help would be greatly appreciated.
(located in east county)
PM me for my number/address. I will check late tonight and early tomorrow.
thanks!
Climbit is offline
post #26309 of 40828 Old 02-14-2012, 12:03 AM
Motorep
thanks!
Sorry, won't be up that early...
Motorep is offline
post #26310 of 40828 Old 02-14-2012, 12:05 AM
Climbit
some come over later... I am sure that it will take me quite a while
Climbit is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
