San Diego Area - Page 1724 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > California Jeep Forum > SanDiego > San Diego Area
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 01-22-2012, 12:53 PM   #25846
jbolty
ISO 9001 Compliant
jbolty's Avatar
Taking a break from replacing my manifold gasket.
good times. at least it's not raining today.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 01-22-2012, 01:52 PM   #25847
Delta347
T-Rex Bait
Delta347's Avatar
Originally Posted by jbolty View Post
Easy swap.
The problem is getting to be finding a booster. The only ones who seem to be rebuilding them is Cardone and they are junk. It took three bad ones in a row before I gave up and ended up with a 98 TJ booster and a Mr Blaine custom fabricated bracket.
If you do this I have a brand new 95 YJ master cylinder in the shed.
I actually bought a 1995 ZJ Brake Booster, it bolts right onto the YJ bracket. Only thing is I think I have to modify the arm that goes to the actual brake pedal. I think its a little too short compared to the YJ one. Because the 95ZJ didn't have a manual option so the booster sat flush on the firewall. Its only a couple inches short. I would need one of you guys though to cut and welder the arm off the YJ to the ZJ one to get the proper length.
It has the master cylinder/resevoir/lines attached.
Does no place sell 95YJ Boosters new?
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline   Reply With Quote
Unread 01-22-2012, 10:23 PM   #25848
04axeman
went up to pancake rock, was a little slick on the trails but overall a great time.
04axeman is offline   Reply With Quote
Unread 01-22-2012, 10:46 PM   #25849
MJ12
MJ12's Avatar
Video to follow...
MJ12 is offline   Reply With Quote
Unread 01-22-2012, 10:52 PM   #25850
Joe Dillard
Electric Chair Operator
Sweet. I ate pancakes that were as hard as rocks and watched football.
Looks like fun times!
Joe Dillard is offline   Reply With Quote
Unread 01-22-2012, 11:49 PM   #25851
Motorep
Motorep's Avatar
Nice pics. I did absolutely nothing today and enjoyed every second of it!
Motorep is offline   Reply With Quote
Unread 01-23-2012, 12:28 AM   #25852
Delta347
T-Rex Bait
Delta347's Avatar
Wish I could say the same. I pushed the dead weight that is my jeep up the hill of my street until I could turn it into my driveway. Then up my driveway which is probably about 30 degrees of incline. I had to line it up and roll in backwards across the street and get a running start. My neighbors must have thought I was crazy took a good 3 tries haha. Surprised I didn't give myself a hernia.
Unread 01-23-2012, 10:04 AM   #25853
shoe83
I bet you were glad you had a good alignment. That could have been ugly.
shoe83 is offline   Reply With Quote
Unread 01-23-2012, 01:29 PM   #25854
Xpress
Xpress's Avatar
Who wants to come over and weld a nut to a stripped out torx so that We can remove it?
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
L.E.D. Guru
Xpress is offline   Reply With Quote
Unread 01-23-2012, 02:05 PM   #25855
StvDiego
What are you trying to remove?
Try this:
Originally Posted by mrblaine
I've told folks about 203 times how to deal with bad Torx fasteners that won't take anyone more than 10 minutes total and each time, there's a bunch of dissenting methods that although they have or might work, they are not infallible 100 percent of the time.
My method is 100 percent foolproof if you follow a few simple rules.
If a Torx fastener even grins at you sideways during the vast majority of any installs, grab a sharp 5/16's drill bit and drill the head off and no more. Do this to all the fasteners that give you crap. Remove whatever they are holding on and then take a pair of needle nose vise grips to the little stub sticking up (thus the reason for not drilling any more than you have to) and twist it out. Works every time, all the time
StvDiego is offline   Reply With Quote
Unread 01-23-2012, 02:34 PM   #25856
Xpress
Xpress's Avatar
Won't work, these things are TIGHT inside of the threads, almost as if someone took make a gasket goo and put a bit inside of there. The last 1/8" gets really tight.
L.E.D. Guru
Unread 01-23-2012, 02:43 PM   #25857
TJRoberto
what do you guys say about this online store?
http://www.knowwhere2jeep.com/drivel...p-oil-pan.html
do you guys things is legit?
I have been searching for a deep oil pan for my 32rh swap, and havent had any luck. summitracing apparently dont offer them any more.
I called all the SD dealership none of them are able to figure out why are they not in stock in any of the US dealer except two and those are in the east coast.
TJRoberto is online now   Reply With Quote
Unread 01-23-2012, 02:44 PM   #25858
aw12345
Probably have loctite on them, apply heat and try when hot, loctite lets go when heated a couple hundred degrees
Tinkertoy built thread
http://www.jeepforum.com/forum/f22/lil-bit-tinkering-aka-tinker-toc-1194198/
aw12345 is offline   Reply With Quote
Unread 01-23-2012, 02:56 PM   #25859
jbolty
ISO 9001 Compliant
jbolty's Avatar
Summit has this one now, looks like the same pan and fits a Torqueflight A999, give them a call.
http://www.summitracing.com/parts/DC...queflite+A-999
Unread 01-23-2012, 06:23 PM   #25860
Xpress
Xpress's Avatar
Guess I can finally bolt my tranny back to the crossmember:
Got them from Ababa Bolt in El Cajon, $0.50 a piece. Got lucky though because it was my first time, guy waived the min $15 card purchase fee. Real grade 8 USA bolts
And so does the paint
L.E.D. Guru
