San Diego Area - Page 1503 - JeepForum.com
 50Likes
post #22531 of 40828 Old 07-11-2011, 02:18 PM
TJRoberto
Originally Posted by 92 Green YJ View Post
I am but I will be working on my YJ at my place. Planning to hit IMS for some more DOM for my cage and Harbor Freight for a new chop saw. Then I need to relocate the drivers side rear body mount cause I didn't get to it last week when I did the comp cut corner on that side. Then I am planning to redo my tail light wiring cause it's a mess, then figure out some of the angles I need for the cage and print and cut some notch templates in preparation for doing the roll cage additions on Wednesday.
Ill be sending you a pm with phone # let me know if you need a hand. I was planning on fixing my rear TC leak and a quick oil change.
TJRoberto is offline
post #22532 of 40828 Old 07-11-2011, 02:31 PM
92 Green YJ
92 Green YJ's Avatar
Sounds good man. Though tomorrow is pretty straight forward. Wed is the big project day
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #22533 of 40828 Old 07-11-2011, 02:34 PM
TJRoberto
I guess there was a misunderstanding, I have today (Monday) off. I think the date and time that our post set are wrong, or in another time zone
post #22534 of 40828 Old 07-11-2011, 03:38 PM
92 Green YJ
Lol. That or I just didn't pay attention and assumed since I saw the
Ost today you meant Tuesday. No worries man
My
post #22535 of 40828 Old 07-11-2011, 03:51 PM
TJRoberto
If you still need a hand after six pm i can still help
using JeepForum iPhone app
post #22536 of 40828 Old 07-11-2011, 08:54 PM
Speed-Freek
Originally Posted by Chris View Post
This may help you identify different axles. Also if you the cover and there is spider gears then you don't have a locker.
I ended up getting that rear end this morning, its a 3.73 not a 4.10, and it was from the Unlimited model.
As far as a locker goes it has the Track lock stock limited slip, but not a true locker.
So I am going to weld up the tubes to the diff and build a medium duty truss, meanwhile I will search for that XJ 4cyl front diff for the HP swap and the regear them both, I will truss the front and weld the tubes as well on that too.
So its getting time for me to get the coilovers and springs so I can be ready for the axle swaps, and at that time I will also do the SYE and new driveshaft so it will all happen at once, just getting all the parts together, gearing, lockers and all the trussing and welding
So glad I finally found a rear axle to build..
I still keep going back and fourth between 33" and 35" tires, cant make up my mind...I am kinda thinking of going with 33 x 10.5 or 35 x 12.5, with the 33" tires I can use my wheels and just get spacers to save a bit of cash, but bigger tires allow me to go more places, however it seems that 35" is that mystical number where you will need to start beefing up the brakes and steering system (more $$$$$). Oh boy what to do..
ASE certified tech, and welder/fabricator for hire, PM me for any of your automotive needs!
Speed-Freek is offline
post #22537 of 40828 Old 07-11-2011, 09:19 PM
jbolty
jbolty's Avatar
So I just got back from a short trip to Texas, visiting friends and attending a wedding. I can say with certainty that any one who thinks there is a good, authentic BBQ here in San Diego is kidding themselves.
The people we stayed with belong to a championship BBQ team and even though the team was recently formed they have won a few trophys.
They take it seriously down there and the results prove it
Here is some of the the equipment for a simple hobbyist.
trailer bbq pit.
trailer mounted walk in cooler
second pit with a water tank and sink
jbolty is offline
post #22538 of 40828 Old 07-11-2011, 09:26 PM
Speed-Freek
trailer bbq pit.
Wow, that what I call a Barbeque!
post #22539 of 40828 Old 07-11-2011, 10:02 PM
92 Green YJ
I dunno Jeff, while I agree Texas has some killer Q (the salt lick stands out in my mind) ya gotta admit Phils does a heck of a good job for local Q
My
post #22540 of 40828 Old 07-11-2011, 10:34 PM
TonysTJ
Is anyone familiar with Crab Flats campground near big bear? Some friends and I plan on spending a weekend there soon and I am new to the area so any advice or suggestions on trails or anything else from your experience would be greatly appreciated?
TonysTJ is offline
post #22541 of 40828 Old 07-11-2011, 10:41 PM
RikRotorhead
Pine trees everywhere.
Chris will probably chime in tomorrow and tell you what ever you want to know. He's from that area.
What trails will you be running?
Be specific on what you want to know so he can answer.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #22542 of 40828 Old 07-11-2011, 11:17 PM
EJames1226
EJames1226's Avatar
trailer bbq pit.
I had the best smoked BBQ when I was in Oklahoma at my fiance's family's house.
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #22543 of 40828 Old 07-11-2011, 11:31 PM
Delta347
Originally Posted by Speed-Freek
If anyone needs car work done by a professional mechanic let me know, I work from home and thats my Primary business. I was a Master Toyota/Lexus tech and also worked as the lead Heavy line tech for Diesel Masters, so I know my way around gas and diesel engines, and motorcycles as well, been self employed for the last 8 years now
Maybe you can tell me why my AC relay isn't getting power to turn on the compressor. It's getting a on signal to activate the relay but I had to run a jumper wire to the relay from the headlamps which get power directly from the battery via the PDC junction. In my 95 ZJ and why my engine hates idling after stopping for a few mins when the ECM and sensors are fine
Ive finally secured a place to do the engine swap in my 90 YJ so if I have trouble I'll know who to bug first now. though my girlfriend's brother in law who is offering his garage is in charge of a marine corps mechanical shop at Pendleton so I hope he knows his way around things though he is on deployment so I have to await his return...maybe I'll be able to install a full exhaust at this rate too. Need a catalytic and muffler mine are rusted through and through
On a different note is this the Wildomar OHV area spoken of a few days ago?
http://www.riderplanet-usa.com/atv/t.../ride_7684.htm
My iPhone will poison your Android.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #22544 of 40828 Old 07-11-2011, 11:36 PM
Delta347
Idk anything about the big bear area but my girlfriend owns a cabin up there so if you find any info or good trails do mention it! Always good to know trails in the places we go!
Delta347 is offline
post #22545 of 40828 Old 07-11-2011, 11:52 PM
Chris
Guy with jeep
Chris's Avatar
Let me know what you need to know and I can probably answer it, its a pretty nice and central area for wheeling the mountain. Your profile doesn't say if you are locked or not but I would definitly recomend Holcolm creek trail from that area to fawnskin but if you are not locked you will be better off going from Fawnskin down. It's a very scenic trail with alot of water crossings. Other than that john bull is fun but somewhat challenging for some and also gold mountain and pontiac sluce are good ones. While up there go by the discovery center and grab a map of the trails it will help you out a lot.
Shh don't tell everyone. BTW the lake has been awesome up here the last few days.
Chris is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
