San Diego Area - Page 1500 - JeepForum.com
 50Likes
post #22486 of 40828 Old 07-07-2011, 10:36 PM
'92 vegas YJ
Originally Posted by Speed-Freek View Post
I have one too, but I am in Vista...kinda far from you.
Originally Posted by EJames1226 View Post
Whatever is easier for you, Im off the I-15 at bernardo center drive
Originally Posted by StvDiego View Post
I have one too, it's at Jeff's in the truck if that's closer for you...
man you guys are quick.
i think i will first try Steves which is at Jeffs and isnt too far from my place. but if anything falls through i will definitely be hitting one of you guys up again to try to snag one.
thanks guys
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
post #22487 of 40828 Old 07-08-2011, 12:44 AM
92 Green YJ
92 Green YJ's Avatar
May as well toss my hat in the ring. I have a scanner too in OB. Had to buy one when they passed that law.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #22488 of 40828 Old 07-08-2011, 12:45 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by 1990JEEPXJ View Post
so when are these going in?
The day I ordered it, Nate (from Artec) mentioned that they were getting a shipment of the teflon kingpin inserts in a day or two and as soon as they arrive, my order should ship. I expect to get the arms early next week (fingers crossed).
I have a set of 7/8" steering heims & weld-in bungs (basically his kit minus the tube) coming from Dan @ RuffStuff. I'll get them in a day or so.
I'm going to buy the steering tube (DOM or chromo) locally. So as soon as I get all that stuff, I'll do the install and kingpin internals inspection (bearings etc).
aw12345 offered to let me borrow his 7/8" allen wrench so that I can disassemble the kingpins. He's up in the Ontario area & I'll be stopping by his house tomorrow evening so I can pick-up a 35 spline chromo outer he had for sale. I'll ask if I can borrow the wrench at the same time.
All that said more than likely it'll be sometime next week.
Originally Posted by Delta347 View Post
Anyone here confirm that a 91-95 fuel pump will fit into a 1990 fuel tank with little to no modification? I was asking in the forum for Fuel pump recommendations without replacing my tank all together and some one said buy the pump and it will fit in the tank even though my tank didn't have the internal set up ever....will It mess with my sending unit at all?
If it doesn't work - I'll have my '91 tank available in a few weeks.
Joe Dillard is offline
post #22489 of 40828 Old 07-08-2011, 01:08 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
right on. and next week i have a pretty open schedule if youd want a hand.
1990JEEPXJ is offline
post #22490 of 40828 Old 07-08-2011, 09:52 AM
shoe83
Anyone here bought anything from Flatblack Fab? They post just about daily on craigslist. I'm considering a set of tube fenders, and they will build and install them for $400
shoe83 is offline
post #22491 of 40828 Old 07-08-2011, 10:08 AM
StvDiego
I haven't seen their work firsthand, but, $400 installed for flat fenders isn't bad if you can't do the work yourself.
My only issue would be that it looks like they have no flare so larger tires would really hang out there, may not be so good for a DD...
I got flat fenders after badly munching both my front fenders to the point where they were unrepairable, otherwise I wouldn't have bothered. I picked up a 3" flare flat fender kit from C&C Fabrication eBay Store . They were cheaper back when I got mine but at the current price of $245 shipped they are the most complete and easiest to assemble and install kit I've seen with minimal welding. Worth checking into.
I'm curious what metal Flatback uses for their full cages...
StvDiego is offline
post #22492 of 40828 Old 07-08-2011, 11:15 AM
'92 vegas YJ
I don't run flares on my tubes at all and haven't run into any problems. Not saying that I never will, just haven't yet
post #22493 of 40828 Old 07-08-2011, 02:34 PM
aw12345
If you buy tube fenders with flares on them find the kind where the front angles back at 30 degrees or so you will be glad you did when you play in the rocks.
aw12345 is offline
post #22494 of 40828 Old 07-08-2011, 04:22 PM
shoe83
Thanks for all the input guys. I'm not quite ready to buy anything yet though. I do need to do some maintenance on my jeep though. Anyone wrenching this weekend?
shoe83 is offline
post #22495 of 40828 Old 07-08-2011, 11:48 PM
'92 vegas YJ
does anyone know where i can get some CHEAP brake lines for right now.
i just need a driver front for right this second.
i had a little incident yesterday in the hoopty that ended up with me cruising down a hill at about 30mph coming up on a red light and applying the brake and my foot going straight to the floor. i tried pumping to no avail. i ended up down shifting and whipping a 100% illegal u-turn at the intersection to avoid going into it and dying. hahah also by doing this i was able to lose my momentum because it sent me back up a hill now. i was able to pull over and access the damage.
apparently my driver front tire had been rubbing my brake line and rubbed a hole right into it.
you mean its not supposed to do that?
again i just want to find a place that i can get a replacement for cheap just to get me around for now. the jeep is not a DD but i still like to fart around town in it occasionally.
-chris
post #22496 of 40828 Old 07-09-2011, 12:01 AM
Vern Britain
what u going to do on the steer? Ram assist wont work...full hydraulic?
Cant Dive 55
My Website
Vern Britain is offline
post #22497 of 40828 Old 07-09-2011, 02:44 AM
Delta347
If the '91 tank comes with the pump, mounts (if any), filter, level reader (if different than mine) and all that jazz and can bolt right in that may be the easier route than trying to modify my current tank. And if it comes at a reasonable price. Does the level reader from a 91 work with the 90? I think they still had the same gauges?
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #22498 of 40828 Old 07-09-2011, 03:28 AM
Joe Dillard
From what I've seen, the hydro assist should work fine.
I was at aw12345's place this evening & my steering will be similar to his steering set-up at some point (but not at first).
The drag link will tie into the top of the passenger side high steer arm, while the tie rod will connect somewhere between the arms & the knuckle mount thru the bolt/sleeve the kit provides (but not at first. after I add hydro assist). Making it similar to placing the tie rod in a double sheer. This will make it a crossover steering style system.
The hydraulic rod will also tie into the tie rod near where it mounts to the knuckle and at the other end to the axle tube near the housing.
I'll only have the tank - nothing else.
The guts of my stock tank will be moved into a fuel cell.
post #22499 of 40828 Old 07-09-2011, 03:39 AM
Delta347
Well I'll see what can be done once I get the fuel pump, which probably wont be until a few weeks go by anyways...Just trying to keep things as cheap as possible at this point:
Pump:150 + shipping
Maintenance Parts: 150
Exhaust Manifold: 200-300
I can only push a 100$ a paycheck for the project as is.
Delta347 is offline
post #22500 of 40828 Old 07-09-2011, 09:21 AM
StvDiego
I'm pretty certain I have some stock ones on a pile of calipers I have at Jeff's
StvDiego is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
