San Diego Area - Page 1408 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > California Jeep Forum > SanDiego > San Diego Area
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 02-10-2011, 07:38 PM   #21106
shoe83
I decided on a meet up place for the Pancake Rock run on Sat (Feb 12) at 10am. We will meet at the Circle K in Alpine at Here is the address:
1666 Alpine Boulevard
Alpine, CA 91901
shoe83 is offline   Reply With Quote
Unread 02-10-2011, 07:59 PM   #21107
kuruma
Originally Posted by StvDiego View Post
Hemi swap (you'll need to change the tranny too) and D60's, only reasonable thing to do at this point
No problem got an extra 6.1 layin around I can take off your hands? I'll trade you a case of beer for it. Whadaya say Natty Light? If I did any swap it'd be for a diesel with the Genright Safari gas tank. That way I could go for miles without a fill up.
Chrysler is actually staying on top of it pretty well. They have called me about 6 times getting updates and updating me on what they are telling the dealer. Hopefully it will be fixed in the near future.
kuruma is offline   Reply With Quote
Unread 02-10-2011, 11:42 PM   #21108
Climbit
Originally Posted by Motorep View Post
Will you be ready for TDS?
yea... I am going to make a trip to the JY next week for all the parts for the 231 swap. the Aussie will also go in next week.
and if there is time I will get my header fixed next week... if not the week after.
I'm debating trying to get my rocker replacement done before TDS...
I figure it will take 2 or 3 days of Fab work. if I can fit it into my schedule I will get it done.
[URL="http://www.jeepforum.com/forum/f22/climbits-daily-driven-weekend-wheeling-affair-1191536/"]Build[/URL]
[CENTER]JF Recon member #43[/CENTER]
[COLOR="White"][CENTER]White Jeep Club Member 127[/CENTER]
[/COLOR]
[QUOTE=RikRotorhead;14565104]
I'll buy you a beer when I see you and we can kiss and make up. lol :cheers2:[/QUOTE]
[QUOTE=YJames90;14618050]I'm gay[/QUOTE]
Climbit is offline   Reply With Quote
Unread 02-11-2011, 12:14 AM   #21109
1990JEEPXJ
1990 XJ Cherokee
good call on the rocker replacement. i will end up doig that one day too. i have a nice dent in mine under my front passenger door.
My POS
1990JEEPXJ is offline   Reply With Quote
Unread 02-11-2011, 12:19 PM   #21110
jeeps123
Alright guys, I need some help -
How do you shoehorn bigger springs in?!
I tried to install my 2'' lift yesterday, and got stuck halfway through. What do I need to disconnect, to drop the axle far enough? The swingarm? Steering mechanisms?
Aagh..........
free or cheap
jeeps123 is offline   Reply With Quote
Unread 02-11-2011, 12:24 PM   #21111
Climbit
Aagh..........
what suspension style are you running? leaf springs? coils?
you'll want to disconnect the drag link from the pitman arm to drop the axle low enough to get the new springs in.
if you have leaf springs then other than that you will need to unbolt the shocks, track bar and the sway bar from the axle.
if you have a TJ or XJ with a coils suspension, you will need to unbolt the track bar, sway bar, drag link. its not necessary, but you can unbolt the upper CA's and the driveshaft to allow even more room to work.
[/COLOR]
Unread 02-11-2011, 12:30 PM   #21112
jeeps123
Context is great, isn't it? Yep, its a TJ. I was talking about coil springs, in the front.
free or cheap
Unread 02-11-2011, 12:49 PM   #21113
kuruma
Aagh..........
Easiest way is to pick up a spring compressor. You could probably find one at Harbor Freight for not too much. I'm on the lookout for one as well. Had a spring pop out on the trail and it was a booger to get back in until someone ran home to grab theirs. I'm going to see what the trails are like here and maybe throw one in the tool box just in case. I usually pack overkill for runs but I've never had to leave the Jeep on the trail either.
Unread 02-11-2011, 12:51 PM   #21114
Climbit
yea.... that helps.
in the front you should unbolt the sway bar links, the drag link at the pitman arm, and the track bar. you can also unbolt the upper CA's and driveshaft for a little extra working room.
in the rear you'll want to unbolt the sway bar links, and track bar at least.
Edit: you could go the spring compressor route... IMO those things are a PITA and really only useful for emergency trail repairs, or small cars.
[/COLOR]
Unread 02-11-2011, 01:10 PM   #21115
92 Green YJ
yeah id kick the sway bar loose and maybe the track bar. that should give you enough droop to shoe horn them in. As I recall that was what we ended up doing to put the 2" lift coils in the front of Erics XJ way back when
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Unread 02-11-2011, 02:54 PM   #21116
StvDiego
All of the above; disconnect sway bar, shocks, probably have to disco one end of the track bar,and remove the wheels of course...
Be sure it's safely on jack stands and then for a little extra use a floor jack under the rotor on one side and slowly jack that side up, the other side will drop down.
I've installed quite a few 4" spring lifts an TJ's and have yet to use a spring compressor. I do have a cheater bar that is flat one end that I've used to encourage a spring or two to cooperate a time or two though.
And if all else fails get Eric or Jimmy to stand on top of the axle on one side, it'll drop wayyyy down
StvDiego is offline   Reply With Quote
Unread 02-11-2011, 03:01 PM   #21117
jeepnkal
You working today?
jeepnkal is offline   Reply With Quote
Unread 02-11-2011, 05:51 PM   #21118
imustbenuts
Don't use compressors!
Unhook sway bar links, axle end of track bar, and shocks. Put the passenger side in first. Use jack to lift driverside of axle up to bump stop. Push passenger side down and slip in spring. The driver side can be done without lifting passenger side. You must put passenger side in first. I put in 4" springs like this.
To remove front springs always do driver side first.
If you need help may be able to shoot by. Where in SD are you?
On my first trail run:
http://dl.dropbox.com/u/14898082/The%20Bump%20ABD.mov
imustbenuts is offline   Reply With Quote
Unread 02-11-2011, 06:57 PM   #21119
StvDiego
Originally Posted by jeepnkal View Post
You working today?
Nope, come on downtown, bbq ribs and
Unread 02-11-2011, 07:45 PM   #21120
jeeps123
I've been fiddling with it for hours, didn't even see your post......
I live in Del Cerro, 92120. I'll be back at it at 7am Saturday, so if you're in the area, come on by (i have work between 11:45 and 4pm) morning or afternoon
5488 Barclay Ave
Using a lot of leverage, I already got the passenger side in. I could still use help (or a word of advice) on the rest. Havent been able to get the steering disconnected, or the track bar, but that's the first thing I'll be working on tomorrow.
Thanks dudes!
phone (619 three four seven 8232)
free or cheap
