San Diego Area - Page 1347 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > California Jeep Forum > SanDiego > San Diego Area
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 11-05-2010, 01:45 PM   #20191
EJames1226
DW still there. Its officialy bump induced DW. I hit a bump goin 35 and it started wobbling like mad
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline   Reply With Quote
Unread 11-05-2010, 02:04 PM   #20192
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Get your wheels / tires balanced, if that doesn't do it, get a professional alignment somewhere that uses the laser thingy or whatever it's called. If it's still there, you could always mask it with an extra steering damper!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote
Unread 11-05-2010, 02:19 PM   #20193
RikRotorhead
RikRotorhead's Avatar
Shoulda' bought a YJ.....
Just sayin'.
Zombies hate fast food.
Guns don't kill people, guns kill dinner.
RJC#512
RikRotorhead is offline   Reply With Quote
Unread 11-05-2010, 04:35 PM   #20194
Climbit
this means almost certainly that it is due to your track bar and drag link not being parallel.
a drop pitman arm and or track bar relocation bracket will fix this.
you may need both but probably not at 2.5"
[URL="http://www.jeepforum.com/forum/f22/climbits-daily-driven-weekend-wheeling-affair-1191536/"]Build[/URL]
[CENTER]JF Recon member #43[/CENTER]
[COLOR="White"][CENTER]White Jeep Club Member 127[/CENTER]
[/COLOR]
[QUOTE=RikRotorhead;14565104]
I'll buy you a beer when I see you and we can kiss and make up. lol :cheers2:[/QUOTE]
[QUOTE=YJames90;14618050]I'm gay[/QUOTE]
Climbit is offline   Reply With Quote
Unread 11-05-2010, 05:39 PM   #20195
sene
Originally Posted by smartshot View Post
Sure dude i got a jack you can use no problem. might be better cause I am getting a house so I'll have a garage.
Thanks
Did you find a place in Pasadena? Have you ever installed fog lights? I had got stuck in some pretty bad fog when I went camping this weekend and picked up some fog lights.
There's a desert run this weekend, and I still owe you guys dinner - I'll call you this weekend.
sene is offline   Reply With Quote
Unread 11-05-2010, 05:41 PM   #20196
EJames1226
Climbit, I just read that a pitman arm won't fix it. I was about to go try too. Is it worth getting an alignment if I don't have an adjustable track bar?
Unread 11-05-2010, 05:47 PM   #20197
sene
I just did the RC 2.5 lift as well, didn't drop the TC and no death wobble for me.
I get a slight rattle in my glove box around 30 MPH but thats it.
My kit sure rides rough though, how does yours ride?
Are you going to the Sunday run? If you are you can see how mine rides without the TC drop.
Unread 11-05-2010, 05:53 PM   #20198
EJames1226
If I can fix the dw is love to go.my kit rides better than stock by far
Unread 11-05-2010, 06:07 PM   #20199
sene
Maybe my RC 2.2 shocks are toast then... I wonder if getting rid of the TC drop would help? I doubt it but worth a try maybe
Unread 11-05-2010, 06:09 PM   #20200
Climbit
the only thing that will change with your alignment is your steering wheel will be off center. IMO why pay a guy when you can re-center that for free in your driveway pretty easily. unless you have an adjustable track bar, then the axle can be re-centered. but that will not change your DW.
since it is a sold axle the toe in does not change with a lift.
a drop pitman arm will only fix your DW if it lines up your track bar and drag link again. the way to figure that out is to disconnect your drag link at the pitman arm then lower it the amount that a drop pitman arm would drop it. if they are back in parallel then that is what you need.
you may also want to consider a track bar relocation bracket... but you will need to get an adjustable to run that.
also.... check all your u-joints for any slop, that can create all kinds of vibes.
[/COLOR]
Unread 11-05-2010, 06:22 PM   #20201
EJames1226
Alright thanks, dw is frustrating lol
Unread 11-05-2010, 06:24 PM   #20202
jbolty
ISO 9001 Compliant
jbolty's Avatar
All good information but the toe in can change if the caster angle changes; worth a check in any case.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 11-05-2010, 06:24 PM   #20203
Climbit
I guess this should end up in TJ tech at some point.... pics of your driveline angles and steering/track bar would help.
[/COLOR]
Unread 11-05-2010, 06:27 PM   #20204
Climbit
I was under the impression that the change in castor would have a low effect on toe as long as you are under 4" or 5" of lift.
and if RC is smart they will use slightly longer lower arms to keep that in check.
but you can check your own toe- in with a tape measure and some spraypaint.
[/COLOR]
Unread 11-05-2010, 06:39 PM   #20205
EJames1226
Heres some pictures.
