San Diego Area - Page 1342 - JeepForum.com
 60Likes
post #20116 of 40864 Old 10-28-2010, 01:15 PM
jbolty
jbolty's Avatar
Chris has a hood lock like this.
Amazon.com: Megatronix - HL5 - 5 Foot Mechanical Hood Lock With Starter Cut Off, For Compact Vehicles: Automotive
It's not really hidden but seems pretty secure and there is no reason not to do a second switch for a fuel cut off.
jbolty is offline
post #20117 of 40864 Old 10-28-2010, 03:13 PM
RikRotorhead
Originally Posted by Motorep View Post
Desert run next Sunday the 7th. Stay tuned...
Where do you plan to leave the pavement?
I'm coming from the north so it is easier for me to get to scissors junction (S2 and 78) than to meet at Santa Ysabel. No reason to go up and over the mountain at Julian if I don't need to.
Map if you have one?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #20118 of 40864 Old 10-28-2010, 03:29 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by taphorn View Post
Okay, got my savvy rock slider steps today, who wants to come help with install? I'll be painting probably tomorrow to start putting them on friday or saturday. Depends on if I need them this weekend or not
I'd help but I gotta fly out to Chicago this weekend. Just make sure to take your time setting the inserts and take great care to drill their locations underneath PRECISELY. Also, a little dab of antiseize dabbed under the insert setting tool's bolt head and its threads that Savvy sent you will do wonders for its longevity and effort needed to set the inserts. Enjoy, those are great sliders.
Oh, did you get the stainless steel or the carbon steel rub rail? I had trouble keeping the carbon steel rust free because I didn't want to paint it. I had to keep wiping it down with oil so I wished I had gone with the extra-cost stainless steel version instead.
After that Jeep was stolen, I bought Gerald's (from Savvy) black Rubicon and he black anodized all the Savvy equipment mounted on it. I miss the natural aluminum look.
Too bad I don't get home until 1am Friday night before you guy's desert trip, I would have made that one!
Jerry Bransford is offline
post #20119 of 40864 Old 10-28-2010, 04:27 PM
taphorn
I'll painting everything this weekend, I plan on fitting everything tomorrow to make sure it goes together. Then prep and paint all weekend with reassembly either Sunday night or Monday. I got the slider steps which they only make in carbon steel. I want to put a good layer of paint between that and the aluminum because those two metals don't play real well together.
taphorn is offline
post #20120 of 40864 Old 10-28-2010, 05:05 PM
jbolty
jbolty's Avatar
I think the plan is to start at Oreflame, which is right at the Banner store. Maybe 5-8 miles from scissors crossing.
jbolty is offline
post #20121 of 40864 Old 10-28-2010, 05:10 PM
TJRoberto
Jey Jbolty I still don't know that area very well. Can I meed with you at your house?
TJRoberto is offline
post #20122 of 40864 Old 10-28-2010, 05:15 PM
jbolty
jbolty's Avatar
Sure. We can meet here or ramona or at dudleys, what ever makes sense.
I'm sure Keven will start a thread eventually.
jbolty is offline
post #20123 of 40864 Old 10-28-2010, 05:25 PM
jbolty
jbolty's Avatar
Originally Posted by Delta347 View Post
Hey Jeff, I'm putting in the Mopar Tranny Cooler I got out of a V8 Grand Cherokee awhile back at the Junkyard. I remember you put in a filter system with yours and had bought some kit, will I be able to just fabricate a mounting system for the cooler and just connect it into the tranny cooling lines or will I need to get a version of the kit that does (or even doesnt) have the filter segement?
Just wanna know basically if I can get away with buying some hoses and clamps or if I need a cheap kit at the least.
BTW. It seems to work best if you put the second cooler after it comes out of the radiator. The the flow should go out from the front most connection on the transmission and return to the other one.
jbolty is offline
post #20124 of 40864 Old 10-28-2010, 05:31 PM
RikRotorhead
So it makes more sense for me to meet you at the Banner store. No need for me to drive all the way down, then up the mountain, then down the long and winding road, that leads to the store......
What time at the Banner Store? 9:30?
RJC#512
post #20125 of 40864 Old 10-28-2010, 06:06 PM
Climbit
its Oriflamme
I have hiked it, never driven. the road follows one side, the trail goes down the middle. unfortunately I can't make it this Sunday. work
and a quick google search gave me this
I expect to see similar shots
Climbit is offline
post #20126 of 40864 Old 10-28-2010, 08:37 PM
RikRotorhead
Originally Posted by Climbit View Post
its Oriflamme
It's not this next Sunday. This Sunday is Halloween.
It's the Sunday after it, the 7th. The next one after Halloween.
Do you work every Sunday?
RJC#512
post #20127 of 40864 Old 10-28-2010, 08:43 PM
Climbit
ahhh....I do work every Sunday, unless I take a day off.
I am already taking the 14th off and the 28th.
however, I will check and see if anyone can work for me on the 7th. then I will come out.
Climbit is offline
post #20128 of 40864 Old 10-28-2010, 10:14 PM
EJames1226
EJames1226's Avatar
Hopefully i should get my lift tomorrow, and then install it this weekend.
Hopefully ill be able to make the trip you guys are talking about too!
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #20129 of 40864 Old 10-28-2010, 10:18 PM
sene
Originally Posted by smartshot View Post
No problem Sene- how's the lift working for you? did you setup your spacers? What's wrong with your diff? Let me know if you want to head up to big bear or to do a desert run.
I like the lift, but it does ride pretty rough, I've been thinking of getting some bilstein or OME shocks to soften the ride but its not too bad. I got a little sad when I saw my mpgs drop with the 32s but then I realized I wasn't calculating that my speedo was off so it stayed about the same
I had a chipped gear in my rear differential it was grinding really bad when the wheels were rolling. Had a local shop fix it but it by the sounds of it I should have just upgraded They re-torqued my spacers when they fixed my differential. Its about time to rotate the tires though, I'll check on them again... do you have a jack I can borrow?
I've got my front recovery point and need to do my rear and I'd be down for the mountains or the desert! I still owe you guys dinner too.
sene is offline
post #20130 of 40864 Old 10-28-2010, 11:29 PM
Motorep
Motorep is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
