San Diego Area - Page 1044 - JeepForum.com
 46Likes
post #15646 of 40699 Old 09-11-2009, 12:15 PM
jbolty
jbolty's Avatar
seats anyone?
Seats for RV
jbolty is offline
post #15647 of 40699 Old 09-11-2009, 12:29 PM
RikRotorhead
So I wanna' get rid of my t-case drop.
I have an SYE kit on the shelf. I have an 8.8, but don't want to wait that long. I need a d30 with 4:10s first.
So temporarily, I could use the SYE and a Cheriokee driveshaft.
I know you already told me Jeff, but I'm old and I forgot. What year Cheriokee drive shaft works? Is it the front shaft or the rear? Does it need to be cut and balanced? Probably huh?
What else do I need to get rid of the t-case drop, or is just the SYE and the driveshaft it? Any flanges or ?
I'm thinking to head to the boneyard tomorrow to find a DS so I can move forward with this.
See my t-case hanging down? It's ugly and hangs up on rocks.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #15648 of 40699 Old 09-11-2009, 12:32 PM
Jeebs
Jeebs's Avatar
To Do List:
Jeff
  • Finish fenders
  • Paint the Jeep
Myself
  • Lift
  • SYE/DS
  • Brake work
Steve
  • Bushings everywhere
  • Front Track Bar Mount replacement
  • Transfer case swap (4:1) / Driveshaft
  • Body Lift
  • Motor mount lift
  • Replace flywheel
  • Rebuild tire-carrier
  • New front bumper
  • Lights
  • Tubliner
  • Wiring problems
  • General maintenance, fluid changes, plugs, etc, and more.
Jimmy
  • Body lift?
  • Axle swap?
Joe
  • Finish painting undercarriage
  • Build a few more SUA HPD30 vacuum disco trusses
  • Finish welding my truss
Rik[LIST]
  • SYE/DS
  • Remove T-Case drop
  • 1" BL
  • TJ Filler
  • Finish Roll Bar
  • Install Stereo
Originally Posted by StvDiego View Post
Maybe I'll just get a new Jeep instead
Might be quicker! Come to the dark side....get a XJ!
Like I said before, we are going to be painting Jeff's Jeep at my place. We can probably get some others done but the garage is booked that weekend.
Jeebs is offline
post #15649 of 40699 Old 09-11-2009, 12:50 PM
jbolty
jbolty's Avatar
Not sure of the years but it's a wide range. late 80's thru at least mid 90's.
front shaft, make sure it has a cardan joint on the t-case end.
it will have to be shortened. if you have to pay to have it done it will be around $100.
or, get a tom woods.
jbolty is offline
post #15650 of 40699 Old 09-11-2009, 12:53 PM
Jeebs
Jeebs's Avatar
Pretty sure I have the front DS you are looking for Rik. I'll check when I get home.
If the Jeep is pulling to the left hard when braking is that the caliper? Maybe the right one isn't engaging the piston?
Jeebs is offline
post #15651 of 40699 Old 09-11-2009, 12:57 PM
jbolty
jbolty's Avatar
either the left is grabbing too much or the right is not grabbing enough.
more likely the right is bad
jbolty is offline
post #15652 of 40699 Old 09-11-2009, 01:02 PM
Jeebs
Jeebs's Avatar
Is it one of those things where if you replace one you should replace both? I don't like messing around when it comes to brakes so I'm more than willing to spend the money to be able to stop!
Jeebs is offline
post #15653 of 40699 Old 09-11-2009, 01:08 PM
RikRotorhead
could be a sticking caliper or just a worn right set of pads.
Replace both, and get the rotors turned while you are at it.
Calipers kits and pads are cheap.
That would be great if you have the DS.
I owe you so much beer already dude.
You're gunna' be sloshed at the next campout!
RJC#512
post #15654 of 40699 Old 09-11-2009, 04:43 PM
KraZeDav
For someone who can completely dismantel a CJ and a simple brake job frightens you, I am suprised.
You take off the wheels,
unbolt 2 retaining bolts holding on the caliper,
buy 2 new calipers with shoes,
have your rotors turned or go buy 2 new ones,
bolt them on,
bleed them,
tires back on,
Done.
Front disc Brakes are easy.
Rear are a little tricky. snap a picture before you take them aprt so you will have a record to put it back the same way.
KraZeDav is offline
post #15655 of 40699 Old 09-11-2009, 04:47 PM
Jeebs
Jeebs's Avatar
You take off the wheels, unbolt 2 retaining bolts holding on the caliper, buy 2new calipers with shoes, have your rotors turn or go buy to new ones. bolt them on, bleed them, tires back on, Done
I think what I said came off incorrectly. I meant that I don't take any short cuts with brakes. I'll go the extra distance with parts and everything brake related.
Jeebs is offline
post #15656 of 40699 Old 09-11-2009, 06:15 PM
RikRotorhead
I put ceramic pads on my front brakes. Didn't notice very much difference, but they don't make as much dust and don't burn so quickly under high heat.
My garage is open this weekend if you wanna' slide on up.
PepBoys charged me $10 per rotor to turn them.
RJC#512
post #15657 of 40699 Old 09-11-2009, 06:43 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Hey Jeff,
I think that I will be needing a welder this weekend to weld two nuts on the front bumper. I need to relocate my license plate. I got yet another ticket from the same parking nazi named Sanders. He did not like the way I had it installed. I am starting to think that sanders does not like Jeeps.
I will get is relocated and signed off AGAIN and pay my $10.00 AGAIN for a fix it ticket.
Group W Bench
CRAWLING 98 is offline
post #15658 of 40699 Old 09-11-2009, 07:27 PM
KraZeDav
It's Easier access to hose out after you've been muddin' Or tossed a bunch of gravel up in there.
KraZeDav is offline
post #15659 of 40699 Old 09-11-2009, 07:33 PM
KraZeDav
Originally Posted by 4x4grey88 View Post
Hey Jeff,
WTH. I don't have one on the front either. Bought it that way. Did get a ticket when I was at Mission Bay about a year ago. I just paid the fine. That sucks. What part of town.
KraZeDav is offline
post #15660 of 40699 Old 09-11-2009, 07:36 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
My MIG is available as well, so if Jeffs doesn't pan out - you are more than welcome to use mine or anything else you may need that I have.
I'll be working/welding/cutting/grinding/etc in my garage on & off all weekend, so it's no big deal at all.
If ya' wanna play with my new plasma cutter - we can cut your Jeep in 1/2.
Joe Dillard is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
