Need some help with a leak from the axle. - JeepForum.com
post #1 of 5 Old 07-19-2010, 02:15 PM Thread Starter
Gomez
I posted this in the TJ tech forum but I'm hoping one of you SD experts may be able to help.
http://www.jeepforum.com/forum/f9/go...9/#post9813875
Gomez is offline
post #2 of 5 Old 07-19-2010, 02:58 PM
Bajachief
D30 passenger side seal
Looks like leak from passenger side axle seal. I just changed the seal on my YJ, and it was somewhat of a Pain. Hardest part was getting the new seal back in (straight). Unless it is dripping a lot and you can see it on the ground I would keep driving. Search Stu-offroad.com and he has great write up on how to fix.
Good luck
Bajachief is offline
post #3 of 5 Old 07-19-2010, 03:06 PM
jbolty
jbolty's Avatar
The carrier has to come out to replace TJ axle seals.
D-30 Axle Shaft Seal Replacement - 1
It's not as hard a job as you would think but it will still probably take all day, if you have never done it before..
jbolty is offline
post #4 of 5 Old 07-19-2010, 03:10 PM Thread Starter
Gomez
When's the next wrenching weekend?
Gomez is offline
post #5 of 5 Old 07-19-2010, 03:12 PM
Jeebs
2015 JK Wrangler
I haven't had one up here in a while. Perhaps it is that time? I used to host them pretty regularly.
Jeebs is offline
