need jeep shop need San Diego - JeepForum.com
post #1 of 27 Old 01-28-2014, 05:34 PM Thread Starter
jenniferjeep
2010 JK Wrangler
I'm looking for good Jeep shop near San Diego. I thought there was one in the El Cajon area, but cant remember the name of the shop. Can any one in the San Diego area help?
Thanks
jenniferjeep is offline
post #2 of 27 Old 01-28-2014, 07:02 PM
jbolty
jbolty's Avatar
What do you need done?
jbolty is offline
post #3 of 27 Old 01-29-2014, 09:43 AM Thread Starter
jenniferjeep
2010 JK Wrangler
I have a friend who is having spring issues with his YJ.
post #4 of 27 Old 01-29-2014, 10:24 AM
jbolty
jbolty's Avatar
There is National Spring in El Cajon. Bee Line alignment near Pacific Beach and a bunch of other places. It still depends on the actual problem. Are the springs bent, shackle bent or broken, center bolt broken or any of a dozen other things.
I don't think I would trust any of the specialty off road shops to work on a YJ; the guys there have probably never seen one since it's most likely older than they are.
Describe what's going on in as much detail as possible, unless it's a secret. Pictures are good too.
jbolty is offline
post #5 of 27 Old 01-29-2014, 10:39 AM Thread Starter
jenniferjeep
2010 JK Wrangler
The boomerang shackles are getting pushed back to the frame and staying there. It is a 88 yo with a 5 inch lift.
post #6 of 27 Old 01-29-2014, 11:01 AM
GOWAD
It sounds like your boy bend the main leaf, What brand spring dos he have on there ?
And is it the front or the back that is doing that ?
If it's the front is the shackle in front of the tire or behind it ?
GOWAD is offline
post #7 of 27 Old 01-29-2014, 11:11 AM Thread Starter
jenniferjeep
2010 JK Wrangler
Not sure what springs. It is the front shackle in front of the tire. There is not a shackle behind the front tire. I'm not versed in springs. Hoping to find a good shop.
post #8 of 27 Old 01-29-2014, 11:35 AM
jbolty
jbolty's Avatar
You can post pictures and descriptions and the brand of springs and there's a pretty good chance we can tell you what the problem is and how to fix it.
Other than that I would call national spring. http://www.nationalsprings.com/
They have been around a long time and that's their business. I would guess either the main leaf is bent or it's just the shackle binding.
There is another specialty spring shop on the border of national city and san diego but I can't think of the name off hand.
report back
jbolty is offline
post #9 of 27 Old 01-29-2014, 11:41 AM Thread Starter
jenniferjeep
2010 JK Wrangler
Thanks. I will pass this info on and report back.
post #10 of 27 Old 01-29-2014, 03:04 PM
newfish1
It's MY jeep! Passenger side shackle has inverted on me on three different occasions. Two were while offroading, and one was while flat towing. i believe the flat towing was due to driving/turning out of a semi-steep driveway. Anyway, I don't know what brand of springs I have. I bought it that way and previous owner didn't know either. So what i've noticed is when the springs flex, the bottom end of the shackles bend inward-towards the vehicle, rather that outward/away. I've read on blogs and sites (such as Quadratec) that it isn't unheard of for this to happen, and some simply fabricate a bump stop of sorts, or use tow shackles, only use them with the pin/tow connection point facing inward, thereby prohibiting flex above 45 degrees.
Attached is a photo of the current setup. Thanks in advance
newfish1 is offline
post #11 of 27 Old 01-29-2014, 03:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Boomerang shackles will prevent the shackle inversion. Take those tow shackles off and get some boomerangs.
Luck Favours The Prepared
Anticanman is offline
post #12 of 27 Old 01-29-2014, 03:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Read this and report back in the tech section
http://www.jeepforum.com/forum/f12/t...ckles-1379950/
post #13 of 27 Old 01-29-2014, 04:15 PM
newfish1
Thanks- I have read that post before, and am glad that I read it again.
It's hard for me (a novice) to know what the best thing to do is since every setup is different. Boomerangs seems like the cheapest fix for now, although I'd have to find a different way to flat tow.
newfish1 is offline
post #14 of 27 Old 01-29-2014, 04:16 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Move the mounts to the bumper.
post #15 of 27 Old 01-29-2014, 04:22 PM
newfish1
I figured, but there seems to be a consensus that towing from the bumper is risky, as it isn't as strong as the frame.
No idea how much "safer" it is to tow from the shackles though...
Thanks again
newfish1 is offline
