Heart Attack Hill Rollover - Page 5 - JeepForum.com
post #61 of 77 Old 04-21-2010, 12:34 PM
Climbit
^that is how I've always seen it done
Climbit is offline
post #62 of 77 Old 04-21-2010, 01:05 PM
NorCalCon
I like how the Spotter isn't even looking at the Jeep, Tires, or Trail in the seconds before the rollover. He is looking downhill away from the Jeep as she goes more and more passenger.
NorCalCon is offline
post #63 of 77 Old 04-21-2010, 01:06 PM
NorCalCon
Looks like the stock cage held up pretty well and the windshield didn't fold.
post #64 of 77 Old 04-22-2010, 09:43 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Originally Posted by StvDiego View Post
You can see me and Jimmy in the pics of us leading runs there and where always close to the driver's window.
proof:
1990JEEPXJ is offline
post #65 of 77 Old 04-23-2010, 12:57 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by 4x4grey88 View Post
And to keep direction clear from the spotter using words like "drivers" side or "passenger" side instead of "right" or "left". The driver does not know if you are calling out your right or the drivers right
In tense situations, driver and passenger don't work. You have to rely on base instinct and no one ever giving directions says to go down the road and take the first driver turn. It just doesn't work that way. If I send you down the road and tell you to take the first right, you ALWAYS know which way to turn.
Where this gets confusing is spotters have difficulty thinking backwards. A spotter needs to react instantly with a verbal command if the driver loses focus and takes their full attention away from his hand signals and eye contact.
It's also up to the spotter to maintain control of the situation. You have to make the judgement calls as to whether or not the vehicle is staying on line and fix the situation instantly in whatever manner you deem appropriate whether it's a loud bark, or a gentle whisper.
You also have to inspire confidence in the driver so they will let you take control. More than once, I have told the driver if they don't quit watching their damn tires I will walk away and leave them to their own devices.
They don't get two chances at that. More than one stubborn person has looked up the second time from their tires to see me walking away. As the spotter, you have a large responsibility to keep the rig and driver safe. You cannot do that without their full cooperation.
The first time they do it, I stop them, walk up to the door and chat with them quietly. How many tires can you see at a time? They typically reply with the answer of 1 or 2. I quietly remind them that I can see all four, plus the obstacle, plus the line, plus the way to keep them out of trouble. Then I try again. Rarely do I have to reiterate, but when I do, they had best listen or figure it out.
I also never force spotting on folks. Some just want to do it themselves and I'm more than happy to let them do it.
In JV, another aspect of it is if I spot you into a stuck, I will stack, tug, pull, or whatever to get you out. If you ignore my spotting and get yourself stuck, I get to sit there and razz you while you get yourself out. I get you in, I'll get you out. You get you in, you get you out.
I also use very distinct and simple hand signals which are laid out and discussed ahead of time. It's very basic. You turn the direction I point, no waving, no gesticulation, just turn until I quit pointing. When I quit pointing, you hold what you got until I direct you again which I will do when it's appropriate and not until.
I do that with one hand and then control forward or reverse with the other. Forward is a come hither wave, and a straight point back is reverse. I also use a gentle palm down to slow progress.
With two hands and simple directions I can walk anyone that pays attention through a literal minefield of big boulders with few if any mistakes.
Also, I don't let a driver keep moving while I find a better vantage point where they can see me. A pair of closed fists, palms toward the driver, will halt them while I reset my position. I never let a new driver move while I find a better spot. I don't want to get run over and I don't want them to ruin the line I have them on.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #66 of 77 Old 04-23-2010, 01:49 AM
Climbit
x2
Not to brag:
I make a good spotter because I have trained myself to think backwards.
I work as a lighting and Audio technician for live entertainment; everything I do is in reverse. If im sitting in the audience, my left is actually Right, and vice versa, since all directions are based upon the stage. It is rare that I use my right as my right and left as my left. If I start talking to someone on stage and tell to go left, I had better mean their or "Stage" left, if not things get screwy.
Its easy to spot the people new at this; because when they are giving or taking direction they constantly confuse their right/left with Stage right/left. it always makes for a lot of confusion and takes more time. on the trail however it could be disastrous. as apparent in this video
Climbit is offline
post #67 of 77 Old 04-23-2010, 02:04 AM
RockMonster
i dont even know what to say, that spotter had like 10 whole seconds to signal and yell BREAK!!!! the driver was also a huge contrabution she should have deffinatly slowed it down to her comfort level and this probably would have never happend. 2 errors driver/spotter.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #68 of 77 Old 04-23-2010, 08:45 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The only points of blame I place on this particular driver is trusting an idiot spotter that clearly should not be spotting, and not wearing a seat belt. The first is forgivable, the second is not.
I am Savvy
mrblaine is offline
post #69 of 77 Old 04-23-2010, 09:38 AM
little_Jeep
BTW, the word is BRAKE..... it ended up being a BREAK, or a broke
Someone said that the spotter was her husband.... note to self; never let this idiot spot for anyone again.
little_Jeep is offline
post #70 of 77 Old 04-23-2010, 04:39 PM
jgorm
jgorm's Avatar
I can't help but LOL (but do feel bad for the driver). Even if you totally trust your spotter, if loads of people yell "whoa", that means stop immediately!
jgorm is offline
post #71 of 77 Old 04-23-2010, 05:20 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Agreed......
Group W Bench
CRAWLING 98 is offline
post #72 of 77 Old 04-23-2010, 10:48 PM
MacK
2015 JK Wrangler
Originally Posted by RikRotorhead View Post
(yes, I have four sisters, three of which own Jeeps too. It's my dad's fault)
Pictures or your sisters don't exist..
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
post #73 of 77 Old 04-24-2010, 09:49 AM
Nick
2006 WK
Pretty sure they have websites for that.
Anyone know how the driver is recovering?
2001 WJ | 4.7L V8 |
Hemi Club Member 60
1990 White XJ Laredo [Sold]
2000 Silverstone XJ Classic [Sold]
2006 Dodge Charger RT Hemi [Sold]
2001 Jeep Grand Cherokee [Current]
Xbox Live gamertag: XJ Nickk
Originally Posted by DcMuff View Post
Banned for being the cooler Nick
Nick is offline
post #74 of 77 Old 04-24-2010, 05:05 PM
RikRotorhead
I posted pics of two of them already.
Here, I brought it forward for you again.....
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #75 of 77 Old 06-05-2010, 01:13 AM
95wrangler4life
I wont comment more on the video, we know the spotter, should have ran off somewhere and hid under a rock.
But my comment here is this, I watched both videos entirely. I hope she has a smooth recovery and all, but another big thing is getting people to have a clue what to do about the person after the incident. The 1st few minutes after the roll, she was not sitting in the seat, then she was (BIG NO NO) cause she wasnt wearing a seatbelt, people need to stabalize the patients c-spine, which means NO MOVING unless in IMMEDIATE LIFETHREATENING DANGER. I was glad to see that the vehicle was eventually stabalized (by guy holding a strap) better than nothing but get another vehicle or 2 and get straps on it, even if it is on 4 wheels, make it so it can not move. 3rd thing was tell help (911) what the exact situation is, and help them figure out what you need as far as emergency services resources. What else to do, in this situation, as stated, keep the patient's spine immobilized, even if they are in a awkward position, its fine, start making access to them, clearing debris off, removing top (either hard or softtop by any means because if you can its easier on us) remove a seat if you can, cut the roll bar out of the way, whatever you can do, without moving the patient, to give emergency services the best access to the patient. Sometimes emergency service people get hyped up too, and might miss idea's or worry about other issues, but this stuff being done prior to our arrival makes my choices of removing the patient much easier and safer for everyone.
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
