DIY bed liners - JeepForum.com
post #1 of 5 Old 02-23-2011, 02:22 PM Thread Starter
pyrapsm
DIY bed liners
So I am going to take my carpets out of my XJ here soon. Then I would like to in install some type of roll on bed liner. I have seen some posts on here and other forums that mostly use Herculiner. What is the difference between all the other brands?
Some different ones I have found Magnaliner, Plasti-kote, U-Pol Raptor Bed Liner, Dupli-Color, Grizzly Grip and Herculiner.
With so many different types out there, which one should I go!
Pictures would also help!
pyrapsm is offline
post #2 of 5 Old 02-23-2011, 04:21 PM
jbolty
jbolty's Avatar
Never used any of them but according to all the other threads herculiner seems to be the most popular by far.
There is a guy in Santee that does an offbrand version of Rhinoliner pretty cheap. I only have his email avail right now so I'll PM it to you.
jbolty is offline
post #3 of 5 Old 02-24-2011, 12:45 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
if you DD i wouldnt keep the carpet out. the floor generates a lot of heat inside the cab without the carpet as insolation.
1990JEEPXJ is offline
post #4 of 5 Old 02-24-2011, 12:49 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i have used durabak and like it, you can get it smooth or textured, and in many colors, and with or without uv protectant. i suggest smooth as the textured is hard to clean, and since it will be on the inside of your xj their is no need for the uv protectant. a gallon should give you well over 4 coats, maybe 5. i did the outside of my cj with one gallon did 3 coats and i still had extra. i would suggest ordering a quart from them.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #5 of 5 Old 02-25-2011, 07:35 AM Thread Starter
pyrapsm
I have heard a lot about durabak and herculiner in other forums. I guess is mostly personally option they all do the same thing.
So from my conclusion nobody really has any problem with any of them, it all comes down to the prep work.
pyrapsm is offline
