Anyone rebuild engines? - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > California Jeep Forum > SanDiego > Anyone rebuild engines?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 12-07-2011, 09:43 AM   #1
Xpress
Xpress's Avatar
I fear that my engine may be nearing the end of its life (from an abusive PO) and that it may be time to rebuild the entire thing. Does anyone do rebuilds locally, inexpensively? Or does anyone know where I can get a rebuilt 2.5l?
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-2004 Kawasaki KLR650
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
L.E.D. Guru
Xpress is offline   Reply With Quote
Unread 12-07-2011, 10:11 AM   #2
jbolty
ISO 9001 Compliant
jbolty's Avatar
I had my engine rebuilt a few years ago at Kenyon Machine. Good guys and they did a nice job. Not cheap to have it done properly though; $1200 for parts and labor but that included new pistons, bearings, cam, valves and all the machine work.
I'm very happy with the result but if I had it to do over again I would probably go with a chevy 4.3 and a 700r4 transmission.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 12-07-2011, 10:15 AM   #3
Xpress
Xpress's Avatar
I'm not looking for cheap... So much as inexpensive. $1200 doesn't sound terrible for what is essentially a new engine. That was with a 6 cylinder thought correct? I wonder if a 4 cyl would be less expensive..
L.E.D. Guru
Unread 12-07-2011, 10:20 AM   #4
jbolty
ISO 9001 Compliant
jbolty's Avatar
That was my thought as well. I had looked into crate engines but for about the same money I felt the result would be better and from a local guy. The 4 cyl would almost certainly be a little cheaper, at least for parts.
That price was for me delivering the engine to them.
Unread 12-07-2011, 10:22 AM   #5
Xpress
Xpress's Avatar
If I were to get it rebuilt the engine would be pulled myself. Maybe it would give me a chance to scrub out the inside of the engine compartment.
L.E.D. Guru
Unread 12-07-2011, 10:43 AM   #6
Delta347
T-Rex Bait
Delta347's Avatar
You should go find 4.0L heads and parts and buy my 4.2, have its lower half rebuilt, then make a badass stroker.
Just saying.
Why invest in the angry squirrels if youre goal is to escape them.
On a side note, J&J Speed and Automotive was who I was recommended. They are in Poway or the such, 760-215-8504. I decided not to have the engine professionally rebuilt at the time being but they were friendly and had a similar price range for the 6cycl. New everything.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline   Reply With Quote
Unread 12-07-2011, 11:06 AM   #7
gtg413i
2003 WJ
Had mine re-manufactured at motor machine and supply http://www.sandiegoengines.com/ They did a remanufacture vs. rebuild, so it was fairly expensive, but essentially a new engine.
gtg413i is offline   Reply With Quote
Unread 12-07-2011, 10:44 PM   #8
Xpress
Xpress's Avatar
Just saying.
It's going to be a lot of work to swap in the engine, not to mention i have to go through all of the BS to legalize the swap.
L.E.D. Guru
Unread 06-20-2012, 04:18 AM   #9
wikun
1990 XJ Cherokee
I know that this thread is old, but I wanted to throw another guy's hat in the ring. Here is a link to the BBB report. Can't seem to find his website. His shop is old, been around since the early 70's. I had him rebuild my 90 4.0 renix. Great job, military discount, buried in National City, but not too hard to find. Check him out and give him a call. Does all machining in house. Great guy to work with. Alright enough horn tooting.
wikun is offline   Reply With Quote
Unread 06-20-2012, 04:20 AM   #10
wikun
1990 XJ Cherokee
Sorry, that link didn't post..... http://www.bbb.org/san-diego/busines...ity-ca-1005193
