XJ Roof Rust and Paint Prep Help, Pleeez! - JeepForum.com
post #1 of 4 Old 07-12-2017, 10:20 PM Thread Starter
Skerr
I am prepping my son's XJ for paint. It's a 1990, and most of the factory paint is still good. Of course, the clear is flaking on the hood and roof. My plan is to remove the finish wherever necessary, and scuff the finish wherever the paint is still good. Mostly I am scuffing with 80 grit on my DA, and I plan to go over it with the new color. However, the roof needs much more attention. Besides being difficult to reach it all, I am finding several places where surface rust has started and extended underneath the paint. Those areas I am taking down to bare metal. My questions are...
What is the easiest(?) way to remove the finish? I have been using 36 grit on a sander, but it scratches the heck out of everything. And I have tried aircraft stripper, but that doesn't work well either! This is kicking my butt!
Also, I have been applying Ospho to the rusty areas. What do you y'all recommend for rust prep prior to painting? Everything is going to go back in a metal flake bc/cc finish. I don't want the new paint to blow off the roof next year!
Thanks
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2 of 4 Old 07-15-2017, 08:46 PM
rjbruzan
80 grit will not ruin the metal below. You will need to go smoother than 80 to get a nice finish. 280 -360 grit. Any tiny rust pits can be neutralized with a product like rust Mort/Ospho. A quality primer surfacer is next then a top coat.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 4 Old 07-17-2017, 05:39 PM Thread Starter
Skerr
Thanks, Ron. I will follow up with 80 grit after the 36 grit on the roof. I will be applying a high-build primer everywhere. Planning to sand to 320 on the primer, then finish coat.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4 of 4 Old 07-17-2017, 05:48 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Before you go all nuts with 36 and 80 grit everywhere, add some finer grits and try some test areas. I suggest only using high build primer where needed. Spend plenty of time removing failed paint and blending in rough paint.
80 grit for rough sanding before bodywork, and for sanding body filler. 180 grit for final sanding and feather edging body filler. 320 grit for final sanding before using primer and also for sanding spot putty.
CJ7-Tim is offline
