Will metal rust through mill scale? - JeepForum.com
post #1 of 12 Old 09-14-2013, 11:41 AM Thread Starter
TJJeepJosh
Bought a pair of rock sliders and the website advertised them as coming in raw steel. Got them and painted one with duplicolor bed liner (read up on prep- sanding with 180 grit, cleaning with acetone, etc.).
I think there was mill scale on the metal before I painted them and I don't think the sanding got it all off.
My question is could I strip the bedliner and leave the sliders raw with the mill scale on top? or would the metal rust through that?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 12 Old 09-14-2013, 06:42 PM
JeepZJlover
It will eventually rust through the scale I wouldn't do it leave the bedliner alone.
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #3 of 12 Old 09-14-2013, 09:41 PM Thread Starter
TJJeepJosh
Hmm.. need to figure out a way to get more/all of the scale off then. That added to the fact that this duplicolor liner sucks.. comes off so easily.
post #4 of 12 Old 09-15-2013, 09:17 AM
aggiejon
1979 CJ7
Use buffered muratic acid to clean off the mill scale. Brush and rinse, compressed air to dry, the a wipe down with wax and grease remover.
aggiejon is offline
post #5 of 12 Old 09-16-2013, 10:13 AM Thread Starter
TJJeepJosh
http://www.amazon.com/Green-Envy-Mur...d_sim_sbs_hi_4
think this would work? or should I just go get the straight acid
post #6 of 12 Old 09-16-2013, 11:44 AM
aggiejon
1979 CJ7
Probably end up cheaper and faster to just go to Home Depot and buy a gallon.
aggiejon is offline
post #7 of 12 Old 09-19-2013, 05:02 PM Thread Starter
TJJeepJosh
Wonder if a grinding disc rubbed over the surface of the metal would work as an alternative. The acid sounds like the best option but requires a lot of precaution stuff that I'm trying to avoid the work for
post #8 of 12 Old 09-19-2013, 05:55 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Sand blasting is inexpensive, and will remove just about anything. Sandblasting removes oil and silicone contamination, and leaves a texted finish that is perfect for paint or other coatings.
CJ7-Tim is offline
post #9 of 12 Old 09-19-2013, 07:42 PM
oldcelicaracer
Just go and get a zicronic flap disk for a 4 inch grinder and lightly grind down to bare steel,or u can get some aircraft stripper,this stuff will eat through bondo and should make the scale scrape off
Sent from my DROID4 using JeepForum
oldcelicaracer is offline
post #10 of 12 Old 09-20-2013, 06:41 AM Thread Starter
TJJeepJosh
Going to try the disc grinder first since I already have that. How much would sand blasting cost approximately?
post #11 of 12 Old 09-20-2013, 11:17 AM
CJ7-Tim
CJ7-Tim's Avatar
Call around, I can get an entire axle blasted for $40, a bumper should be less. Spending several hours with a grinder kinda sucks.
CJ7-Tim is offline
post #12 of 12 Old 09-25-2013, 02:12 PM
Nutz-n-Bolts
1981 J-Series Truck
Very true. I just used some Herculiner on the bottom of my J10. Works great and is tough. I had bought a gallon of the Duplicolor but returned it when I started reading reviews. ( I read quite a few) Almost no one has great success with Duplicolor. I would totally recommend the Herculiner.
Lover of all Old Iron
60-79 CJ5 The best parts from several years combined to make one tough ALL JEEP CJ
81 J10 Pickup My newest acquisition undergoing a complete restoration
Nutz-n-Bolts is offline
