what's the correct seam sealer?? - JeepForum.com
post #1 of 3 Old 11-08-2010, 07:59 PM Thread Starter
Davidnex
1979 CJ5
who used brush on seam sealer? what were the results? recommendations
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #2 of 3 Old 11-09-2010, 03:52 AM
SRC21
All seam sealers are designed to seal the areas between sheet metal joins. If you want brush able seam sealer to look neat try this. Tape off the areas parallel to the seam. Leave about 1" or 3/4" total coverage over the seam. You can buy brush able seam sealer in a can at most autobody or auto parts stores. 3M or norton is a good choice. Get about 2 golf ball size scoops out into a mixing cup. Mix in a small amount of thinner. It will create a smoother finish and make it easier to apply. Use a small acid brush to apply, then peal the tape off before it sets up 100%. If you want to go for a more $ route you can buy 3M sealer in a caulk type cartridge. You would need to invest in a 3M gun ( the smaller one is about 40.00) and then buy the two part product. It flows and lays smooth with no texture. Open the door or trunk on any new car and you will see what it looks like on the seam. Good luck!
SRC21 is offline
post #3 of 3 Old 11-09-2010, 03:48 PM Thread Starter
Davidnex
1979 CJ5
Yeah, wish I read the answer to my question, before starting, put some on the bottom of TUB, like that tape idea creates clean lines, in-lieu of brush marks..
Inside the TUB purchased Eastwood two part and gun( haven't used), I guess similar to the 3M
thanks for the info
Davidnex is offline
Best sealer adhesive?? Davidnex Paint and Body 2 11-14-2010 09:21 PM
Epoxy Primer/sealer mark12010 Paint and Body 15 09-26-2010 04:15 PM
Seam Sealer? Bigbob Paint and Body 3 05-06-2010 11:32 AM
