Trying to plasticoat - JeepForum.com
post #1 of 5 Old 10-16-2014, 05:08 PM Thread Starter
nicknel5021
So I'm trying to plastic coat parts of jeep but it keeps pulling apart when I pulled the tape off. Any ideas how to correctly trim my vehicle without pulling the plastic coat off?
nicknel5021 is offline
post #2 of 5 Old 10-16-2014, 08:05 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I've never used that stuff but have you tried pulling the tape off sooner?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3 of 5 Old 10-17-2014, 08:17 AM Thread Starter
nicknel5021
I have not but its worth a try
post #4 of 5 Old 10-17-2014, 10:38 AM
Lastshot
Pull the tape while still wet. I like to put down a very thin coat(not full coverage) over the entire area, then come back and spray the middle area normally. Lastly as I get closer to the edge near the tape, I do two thick coats quickly and pull the tape while it is still wet.
This YouTube video shows the method
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #5 of 5 Old 10-28-2014, 04:57 PM
cLuTcH-I-NiNjA
When I plastidipped my wheels and headlight bezels I made an attempt to also plastidip where a grille insert would go. So, with all the curves and tons of little tape bits I wasn't able to tape and retape. What I did didn't turn out flawless by no means, but from a distance it looks ok. What I did was use a razor blade to start the tear when it would try to pull up more of what I wanted to keep.
2003 TJ All stock except the 31's.
cLuTcH-I-NiNjA is offline
