Stainless steel hardware - JeepForum.com
post #1 of 9 Old 09-18-2012, 08:22 PM Thread Starter
ghbatt
Hi guys,
I was looking at the following hardware for my 86 CJ7
http://www.quadratec.com/products/13019_203.htm
I have a replacement fiberglass tub, and am wondering why you wouldn't use stainless steel with fiberglass as it says in the product details? I am looking to replace the body hardware with something which won't rust.
Thanks,
Greg
Check out my Build
http://www.jeepforum.com/forum/f8/gregs-86-cj7-build-thread-1421551/
ghbatt is offline
post #2 of 9 Old 09-18-2012, 08:38 PM
TJs83CJ7
Its not that you can't use stainless with fiberglass, this kit is meant for a steel body so the bolts would not fit through the extra thickness of a fiberglass body. Anybody else can respond if I am wrong. Totally stainless sells individual bolts.
TJs83CJ7 is offline
post #3 of 9 Old 09-18-2012, 09:37 PM Thread Starter
ghbatt
Ah, I see. Thanks for the info.
Are there any kits for fiberglass?
Check out my Build
ghbatt is offline
post #4 of 9 Old 09-19-2012, 09:45 AM
rjbruzan
There must be boat supply houses up there that will sell SS hardware.
If not go to
http://www.mcmaster.com/
They have all sorts of stainless hardware.Just order what you need.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #5 of 9 Old 09-19-2012, 10:41 PM Thread Starter
ghbatt
Thanks for the replies guys. There is no list of what comes in that kit is there? Just so we could build our own kit online
Check out my Build
ghbatt is offline
post #6 of 9 Old 09-21-2012, 02:03 PM
Jims-87YJ
1987 YJ Wrangler
Not sure if you have a Fastenal store near you but they are also a good source for SS Hardware. As far as the Fiberglass body goes the hardware will probably be long enough but on the Metal bodies there are a lot of nuts that are welded into the body, you will not have these on the F/G body so you would probably need to get nuts separate. Just my 2 cents.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #7 of 9 Old 09-21-2012, 07:18 PM Thread Starter
ghbatt
So, the kit would be fine, just buy some extra nuts? That sounds like a good plan, thanks!
Check out my Build
ghbatt is offline
post #8 of 9 Old 09-22-2012, 12:00 PM
TJs83CJ7
GH let us know how it works if you buy the kit and just buy extra bolts... I'm sure buying the kit and some extra bolts would be more cost effective than buying everything single.
TJs83CJ7 is offline
post #9 of 9 Old 10-23-2012, 05:03 PM Thread Starter
ghbatt
Got the kit today, from looking at it, seems like I am going to get my money worth but ill update when it's done...in four months!
Check out my Build
ghbatt is offline
