Spray on Etching primer ok? - JeepForum.com
post #1 of 3 Old 11-11-2012, 07:46 PM Thread Starter
ssdalton
1978 CJ7
I have had to strip my CJ hood because of a PO's roll on job. It has been stripped/sanded to the bare metal in some spots. I have a good quality primer from my body supply shop to shoot the entire Jeep with.
I was wondering if I could spray the rattle can etching primer on the bare metal to keep any flash rust down and would it be compatible with the primer I am going to spray the Jeep with?
I have heard not to use any rattle can primer with the base coat/clear coat paint I am going to be using.
Just want to make sure I'm not going to be causing any trouble with my future paint.
Thanks
Shaun
ssdalton is offline
post #2 of 3 Old 11-12-2012, 07:49 AM
Ironworker709
Ironworker709's Avatar
The reason they say not to use rattle can primer under a good 2 stage top coat is because rattle can paints are bottom of the barrel quality compared to a good base coat/clear coat.
If you have a good 2 part epoxy primer there is no need for etching primer on bare metal,,it is just as good or even better than etching primer because it will bond well to just about anything.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 3 Old 11-13-2012, 05:52 PM
NOCHEEPGAS
1980 CJ5
Standard rattle can primer is not a good idea, but the etching primer may be okay to use. It's hard to determine compatibility between the 2 products, are they from the same manufacturer? If so, it's best to contact them, if not it's a crap shoot. As said above, an epoxy is best for bare metal.
NOCHEEPGAS is offline
