Spray On Bedliner - JeepForum.com
post #1 of 13 Old 07-06-2012, 05:20 PM Thread Starter
SoCalBear
1987 YJ Wrangler
Spray On Bedliner
Has anyone had experience with stripping bedliner? The previous owner coated the whole body with it and it was cool for a while but I am growing tired of it. It's hard to clean and I think a normal paint job would look much nicer.
How hard is it to strip it off?
SoCalBear is offline
post #2 of 13 Old 07-06-2012, 08:20 PM
Ironworker709
Ironworker709's Avatar
It depends on what type was put on..rhino liner and Line-X will be a real PITA to strip..as far as any of the DIY liners...Aircraft Paint stripper can do it with a fair amount of work.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 13 Old 07-06-2012, 11:50 PM Thread Starter
SoCalBear
1987 YJ Wrangler
I should probably get in contact with the guy, I think it was a paint on liner and it wasn't done very well.
Thanks for the response.
post #4 of 13 Old 07-07-2012, 01:21 PM
Jims-87YJ
1987 YJ Wrangler
Well if it wasn't done well it may come off (peel off) fairly easy??? But I think you are in for a lot of work either way...
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #5 of 13 Old 07-07-2012, 01:54 PM Thread Starter
SoCalBear
1987 YJ Wrangler
Yah I was looking at it and in some spots it is starting to come off, especially on the steps. The only thing is he coated the entire Jeep with it, inside and out.
post #6 of 13 Old 07-09-2012, 06:40 PM
StillYDGN
I have a spray on bedliner on my floor plans looks like rustoleum truckbed liner. I want to redo it with a real truck bed liner like monsta or raptor linings. Im thinking i could sand it off like any other paint. Would that work?
StillYDGN is offline
post #7 of 13 Old 07-09-2012, 06:52 PM
Motorcharge
If you value your time at all I'd highly suggest you have it soda blasted. It will cut through the liner but it won't damage the body.
You might have some success with other methods but it's going to take forever to remove unless the prep was terrible and they used something cheap.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #8 of 13 Old 07-10-2012, 10:01 AM Thread Starter
SoCalBear
1987 YJ Wrangler
Hmm, I'll take a look into this, never heard of it but from the couple minutes I was on Google it looked promising.
post #9 of 13 Old 07-10-2012, 05:51 PM
Jayhawk02
Glass beads will warp the metal so be keep it soda and make sure the shop that does it has taken off liner before. My .02
Jayhawk02 is offline
post #10 of 13 Old 07-10-2012, 06:55 PM
Motorcharge
It works very well, but it's fairly pricey. Usually looking at around $1200 to do a full car body, but that's typically inside and out. Absolutely worth it though.
If you go that route just make sure you wash it really, really well several times after. It will wreak havoc on new paint if you don't get it all off the metal.
|SOLD|
| June 2015 COTM |
post #11 of 13 Old 07-12-2012, 03:34 PM
Zone
It's quite possible that neither soda blasting nor glass bead will work. If the bedliner material is fairly soft, the media tends to bounce right off and you will not get desired results. If the bedliner material is hard and VERY thin, then a media blast will work. If the bedliner material is hard and thick, then a media blast takes too long and it won't be cost effective.
You can try a high pressure washer (5,000 psi) and see what happens.
If you're lucky, the owner didn't prep the surface correctly and the bedliner will peel right off, like this:
Zone is offline
post #12 of 13 Old 07-13-2012, 02:37 PM Thread Starter
SoCalBear
1987 YJ Wrangler
Thanks for the help guys, I'll keep looking around at my different options.
post #13 of 13 Old 07-24-2012, 11:18 AM
RebelRidinRyan
1989 XJ Cherokee
I went to WalMart and bought a $7 quart of nylon paint stripper and after a few coats and being patient for the chemicals to work, I take a glass scraper and my liner just peeled right off.
RebelRidinRyan is offline
Best "Over the Counter" Spray Undercoat or Bedliner nsbohn Paint and Body 56 05-02-2012 05:57 PM
Should i use spray on bedliner on the exterior Meyers2010 Paint and Body 35 04-04-2012 09:15 AM
Prepping Tub for Bedliner that already has Bedliner Keith Paint and Body 3 04-22-2011 02:40 PM
Best bedliner zu903 Paint and Body 4 02-23-2011 01:20 PM
painting grill with bedliner, then flat spray paint??? tucanbob Paint and Body 6 09-23-2010 07:18 AM
