Soap Box Derby - Body filler question - JeepForum.com
post #1 of 3 Old 04-09-2013, 06:26 PM Thread Starter
86cj7pete622
This isn't a Jeep question, but it does deal with body filler so I'm hoping I'm in the right section...
My son and I are building a soap box derby car and the body is going to be masonite hardboard (brown colored 1/4", slick on one side, rougher on the other). We're looking for that smooth look so I want to put body filler over the screw holes so that it ends up being smooth and then we'll paint it.
My questions are: with body filler hold to the slick side of the masonite hardboard? Will I need to scuff it? Will the body filler eventually crack on me with all the bumps (small wheels) and the fact that the body will probably not be 100% solid (the frame will be all wood/2x4's, so I'm guessing it'll have some play, I'm hoping for none). Any tips on body filler for this application would be great.
Thanks,
Pete.
CJ7 86, 258, BDS 4", 33's, currently in a frame off resto.
86cj7pete622 is offline
post #2 of 3 Old 04-09-2013, 08:56 PM
BDP72
U might have already got ur mat. But if u have not i would go with 1/2 or 3/4 BC plywood . Then get a kreg kit and use pocket screws and wood glue. It's easy to use and makes a super strong joint and screw holes will be on the inside.
BDP72 is offline
post #3 of 3 Old 04-10-2013, 07:16 AM
thantos858
1974 CJ5
Bondo does work on wood with the smooth surface of masonite you'd probably need to scuff it up for it to hold best. Personally I would go with plywood like BDP72 suggested. If you take your time with sanding you can get it incredibly smooth.
thantos858 is offline
