Seam Sealer? - JeepForum.com
post #1 of 4 Old 03-13-2010, 05:38 PM Thread Starter
Bigbob
Bigbob's Avatar
Seam Sealer?
I am building a trailer. The sides are 1"X2" rect tubing. To that I welded 14 gauge steel. Of course I just tac, tac, taced it on. It is very secure and full welds are going to warp the snot out of it and are not needed. I want to prevent moisture from getting in between the 2 pieces of steel. I know on auto bodies they seal the joints with something.
What is that stuff called? I am guessing it's called seam sealer, but not sure. Do I put it on after I prime the metal or before?
Thank You.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #2 of 4 Old 05-06-2010, 10:38 AM
Zybeon
You could just use a silicon sealant or epoxy that is sandable and paintable. Then of course apply before you paint.
Zybeon is offline
post #3 of 4 Old 05-06-2010, 11:03 AM
mfalik
mfalik's Avatar
It's called "seam sealer"
3M 08405 Flexiclear Body Seam Sealer
There are different varieties that that I'm sure can be purchased from shops that seller body repairs items; however, I have purchased from Auto Body Toolmart.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #4 of 4 Old 05-06-2010, 11:32 AM
AKCowboy
1985 CJ8
It is called seam sealer and NAPA sells it. Put it on bare metal but make sure it is where you want it because it is a PITA to get off.
aka Icicle on Nightcrew.com.
AKCowboy is offline
