Seam Sealer - JeepForum.com
post #1 of 6 Old 06-16-2012, 04:45 PM Thread Starter
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Seam Sealer
I just had a section if subframe in my Jeep replaced due to rot. Now I need to get the seams sealed up because the welds are not one continuous bead.
I've read alot of stuff, and watched a bunch of video's on YouTube. Most of them seem to be fine body work and not a rough patch. I just want to keep this from rusting out again.
My end goal is to spray bomb the new metal and cleaned up original material with bed liner.
EDIT: I can't seem to find the brushable locally. Could I use the caulk gun type and then use a putty knife to spread it?
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #2 of 6 Old 06-16-2012, 04:51 PM
lloydj
Sand it, wipe with acetone , let dry , then spray area with chassis saver, or POR15
lloydj is offline
post #3 of 6 Old 06-16-2012, 07:39 PM
Ironworker709
Ironworker709's Avatar
You can use the seam sealer any way you need to..just buy the tubes of it and spread it where needed,try to "push" it into any loose seams instead of letting it just set on top.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 6 Old 06-16-2012, 07:47 PM Thread Starter
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
That's what I was wondering. Can I get afew tubes and squeeze them out on a pallet and then use a putty knife to apply?
That seems like the easiest way for my application.
dagr8tim is offline
post #5 of 6 Old 06-16-2012, 08:07 PM
Ironworker709
That should be fine..it comes in a tube for a caulking gun because thats the common way to use it..kind of like caulking tiles and bathroom tubs...etc...
It can be applied any way you feel is the best for you....just make sure where you apply it is clean bare metal,that'll be your best bet in the long run,it's a paintable sealer and sticks to paint too,but it works best to bare steel..if the paint you might use on the surface first decided to fail later,than sealer come's off too
Never forget 9/11
post #6 of 6 Old 06-16-2012, 08:24 PM Thread Starter
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Thanks for the info. Once I get it sealed up, it's getting some bedliner and calling it a day. It's the subframe and my Jeep isn't a show rig.
dagr8tim is offline
bed liner , patch panel , seam sealer
Sealer AndreLeMoine Paint and Body 0 05-22-2012 06:15 AM
seam sealer b-dog Paint and Body 3 03-04-2012 08:49 PM
T&T Tube Fender - bondo or seam sealer? TexasTJ22 Paint and Body 14 04-21-2011 05:33 PM
what's the correct seam sealer?? Davidnex Paint and Body 2 11-09-2010 03:48 PM
Seam Sealer? Bigbob Paint and Body 3 05-06-2010 11:32 AM
