seam sealer - JeepForum.com
post #1 of 4 Old 01-10-2012, 08:50 AM Thread Starter
b-dog
seam sealer
have not got my seam sealer yet but do i need to prime the area first or does the seam sealer go on the bear metal?
b-dog is offline
post #2 of 4 Old 01-10-2012, 08:35 PM
ZACHSXE
I've been doing body work/painting cars for a few years now, and I've always just put it on straight metal. Now and then when I get cars with new panels in factory e-coat (factory black primer), I'll scuff them with a red pad quick before I seam seal them.
ZACHSXE is offline
post #3 of 4 Old 03-01-2012, 12:40 AM
Jeeplady13
i agree, if the metal is clean and freshly sandblasted i would put it on bare metal, but it never hurts to apply a primer first let it dry then scuff it up a bit with out rubbing through the primer.
Jeeplady13 is offline
post #4 of 4 Old 03-04-2012, 08:49 PM
FredBull
1993 XJ Cherokee
If its DTM (direct to metal) seam sealer there is no problem, but its best to apply an etch primer first, and then the seam sealer.
Non, DTM seam sealer will stick to the metal initially, but over time it can separate.
What kind are you using? 1k urethane or a 2k? and what are you sealing?
FredBull is offline
Bedlining pinch seam on my WJ Msokol13 Paint and Body 2 12-21-2011 05:42 PM
sealer or no sealer? jwilba2 Paint and Body 6 04-26-2011 08:52 PM
T&T Tube Fender - bondo or seam sealer? TexasTJ22 Paint and Body 14 04-21-2011 05:33 PM
what's the correct seam sealer?? Davidnex Paint and Body 2 11-09-2010 03:48 PM
Seam Sealer? Bigbob Paint and Body 3 05-06-2010 11:32 AM
