Sealing armor ? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > Sealing armor ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Clayton Off Road JK Short Arm Suspension Kits
Unread 02-02-2014, 04:17 PM   #1
3X4X4
Sealing armor ?
I have Savvy corners and rocker armor. This is not a complaint against the product. I love the armor and the quality is exceptional as is the fit. But, moisture can get between any armor and the body panels.
My body was in good shape and I added several coats of rust preventative paint and before installation I coated both the Jeep and the (powder coated) armor mating surfaces with Corrosion X.
However, water can get in there and my concern is all the grit and salt on the roads now. Has anyone ever sealed the edges, at least the upper and forward facing edges with silicone RTV?
I would clean the area to be sealed and then apply a coat of wax and then the RTV. This would allow the RTV to be pulled away and removed (maybe).
Any thoughts?
J
2006 TJ Rubicon, Custom 4 inch lift with Currie Arms, TF springs, RS9000 shocks, TF High Steer Kit, TF ST Dual rate anti-rock, TF front track bar, Yellow Box speedo correction, Black Rock 15X10 Streetlock wheels with BFG AT 33X15X12.5 tires, Line-X tub, Bed Rug carpet, Tom Woods shaft, Spidershade, Savvy corner and rocker armor, Exogate.
3X4X4 is offline   Reply With Quote
Unread 02-02-2014, 05:05 PM   #2
222Doc
that is how i did it. RTV the top and sides, leave the bottom unsealed.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote
