Savvy rear bumper prep and paint - JeepForum.com
post #1 of 5 Old 11-10-2011, 09:41 PM Thread Starter
freeman84
I just ordered a Savvy aluminum rear bumper for my TJ. I plan on painting it black seeing my Jeep is silver. What needs to be done to prep the aluminum for spraypaint? Thanks.
Rubicon with Clayton, Currie, Poly Performance, Superior, Savvy.....and some others
freeman84 is offline
post #2 of 5 Old 11-18-2011, 06:05 PM
ODGREEN4X4
Scuff it with a red scuff pad or 400 grit sand paper ,wipe with pre- cleaner .Then use green death on it . that is zink chromate . Let dry some ( different kinds have different dry times) I scuff it again lightly then THEN TACK RAG ,then shoot it with paint. Let dry -then take it in to the woods and scratch the hell out of it ! Note -DO NOT SKIP THE GREEN DEATH STEP !
ODGREEN4X4 is offline
post #3 of 5 Old 03-05-2013, 09:48 PM
Huey
I'm doing the samething the OP is, but what is 'Green Death"?
Dustin - Best quote ever: TJDualSport: "Right now Blaine is sitting back laughing and sipping his coffee lol. Jeepforum the mind fuc Capitol of the internet."
Huey is offline
post #4 of 5 Old 03-11-2013, 06:10 PM
mg2380
1. Scuff
2. Clean (I used acetone).
3. Self etching primer
4. Paint
mg2380 is offline
post #5 of 5 Old 03-11-2013, 08:29 PM
Huey
That's pretty much what I did on Savvy's rockers. I have moderate OCD, so here are the steps and supplies I used:
Prepping (Al+ and steel):
1) Clean with acetone and paper towels. Let air dry 5 minutes.
2) Sand with 400 grit sandpaper.
3) Clean with acetone and paper towels. Let air dry 5 minutes.
4) Sand with 400 grit sandpaper.
5) Spray with Marine Clean mixed 2:1 (MC:HOT water). Let soak for 20 minutes.
6) Rinse very well with HOT water.
7) Clean with acetone and paper towels. Let air dry 5 minutes.
8) Spray with Metal Ready (full mix). Let soak for 20 minutes.
9) Rinse very well with HOT water.
10) Clean with acetone and paper towels. Let air dry 5 minutes.
Painting:
Aluminum
1) Lightly coat with self-etching primer; 2 coats. Let dry 10 minutes between coats.
2) Lightly coat with Al+ primer: 1 coat. Let dry 10 minutes after coat.
3) Lightly coat with proper paint color; 2 – 3 coats. Let dry 10 minutes between coats.
4) Lightly coat with proper clear coat; 2 – 3 coats. Let dry 10 minutes between coats.
5) Let stand untouched for a minimum of 3 hours to dry.
6) Let set for 1-week before mounting so paint has time to cure.
Stainless steel:
1) Lightly coat with self-etching primer; 1 coat. Let dry 10 minutes between coats.
2) Lightly coat with primer; 2 – 3 coats. Let dry 10 minutes between coats.
I toiled over what to do so I hope this helps others.
Best of luck!
Dustin
Huey is offline
Prep for painting over nice paint bfr Paint and Body 6 03-07-2011 10:08 PM
Half door Prep for spray paint nikeo02 Paint and Body 1 07-25-2010 10:56 AM
How to prep and paint my hood sebastian22 Paint and Body 11 02-13-2010 07:52 AM
How to: Prep and Paint Bad_Influence Paint and Body 5 11-25-2009 09:01 AM
Using a wire wheel to prep for paint? XJoutlaw Paint and Body 2 10-25-2009 07:42 AM
