Satin or Gloss on bottom of tub? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > Satin or Gloss on bottom of tub?
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-23-2014, 06:54 PM   #1
56jeephead
1956 CJ5
I am restoring a 1956 CJ5. I have replaced the floors and am getting close to painting the bottom of the tub. I was planning on using Eastwood's Extreme Chassis Black on the bottom (for durability) I have used it on the frame and this stuff is great. Question I have is what would look better, satin or glossy? I plan on doing the entire underneath and right up the firewall to help seal it against rust.
I know it is not original but I might have the tub sprayed with Bullet Liner (Like Rhino) again to protect the tub. I still plan on keeping the jeep the original General Julip green (Can't remember actual name) Any thoughts would be greatly appreciated.
-Peace
Dave
56jeephead is offline   Reply With Quote
Unread 03-23-2014, 08:27 PM   #2
strvger01
1966 CJ5
i'm a fan of satin. i even have my ruck painted in satin and will be doing the same to my cj5 this summer. doesn't show all the scratches and dings from rocks and whatever nearly as much as the gloss. also makes it easier to blend in the touch-ups that will eventually be done.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote
Unread 03-24-2014, 09:30 PM   #3
thantos858
1974 CJ5
On the bottom either one would work. I would go for the one that makes it easier to clean.
thantos858 is online now   Reply With Quote
Unread 03-26-2014, 06:49 AM   #4
rjbruzan
I use a gloss only to make it easier to clean. But mostly personal preference. Use the best quality material you can afford. Like a catalized acrylic enamel or urethane. This will last longer than the outside due to being out of the sunlight. The same as body color would look great in my opinion.
Love that color!
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote
Unread 03-26-2014, 03:10 PM   #5
Jims-87YJ
1987 YJ Wrangler
I used Monstaliner, could not be happier . I used the light Quartz Gray so when you crawl under it, it's not a black. Check out my build thread in signature.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread: [url]http://www.jeepforum.com/forum/f12/my-very-slow-87-yj-build-thread-1137667/[/url]
Jims-87YJ is offline   Reply With Quote
Unread 03-29-2014, 01:53 PM   #6
bobbowtie
Satin....dont show the dust and stuff like gloss does
bobbowtie is offline   Reply With Quote
Unread 03-30-2014, 11:34 AM   #7
thantos858
1974 CJ5
Its on the bottom so unless your flipping or under it a lot gloss is better for the ease of cleaning.
Unread 03-30-2014, 01:22 PM   #8
magnetman
Caveman Chemist
JeepForum 2012 Vendor Giveaway Participate
magnetman's Avatar
2011 JK Wrangler
Gloss will be more durable and impervious to salt and chemicals.
Anything satin or low gloss has higher levels of pigment and flatting agent and the coating will be more porous.
magnetman is online now   Reply With Quote
Unread 04-02-2014, 08:29 PM   #9
Copperhead89
Quoted for truth. The gloss paint has a slick surface which will be easier to keep clean.
To preserve and protect the new surfaces from rust, I suggest spraying an epoxy primer before the paint.
My Frame-Off, Stroker Magnum V8, SOA YJ/CJ Build Thread: www.jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote
