Rusting welds on 2000 XJ door panels - JeepForum.com
post #1 of 8 Old 06-07-2010, 07:31 AM Thread Starter
jmolare
I noticed that the welds are rusting on the doors of my 2000 Cherokee. The rust is under the clear coat so cannot be treated with reformers and repainted. Eventually the rust will break through the clear coat and can be fixed but there will be more damage by then.
Rusting welds might be a common event in XJ's so there may be others that have faced this problem and have recommendations.
jmolare is offline
post #2 of 8 Old 06-07-2010, 12:42 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Grind or sandblast the rust, treat with acid (Naval Jelly or POR-15 Metal Ready treatment), prime and repaint. "Rust Converter" treatments have never worked, and will never work. POR-15 does work as advertised if you carefully follow the preparation and application instructions.
CJ7-Tim is offline
post #3 of 8 Old 06-07-2010, 08:28 PM
gtome
I disagree. Rust treatments (Picklex or Ospho) work great when done correctly, but they need to be topcoated. I would try to grind out ALL the rust first. If you cant get to the back side, see if you could get in there with one of those garden pump up sprayer wands. Spray some piclex or ospho in there with the wand. And either topcoat with epoxy and paint, or go with the POR15.
You could also use this for the inside if you cant get to it well. There is a long rubber line you can get from 3M too that will help reach hard to get areas. http://www.autobodytoolmart.com/3m-b...4-p-11270.aspx
gtome is offline
post #4 of 8 Old 06-08-2010, 03:03 AM
CJ7-Tim
CJ7-Tim's Avatar
I have tried the rust "converters" several times and they always have failed. Maybe they work if your rust is from salty sea air, but if the rust has bubbled the paint or pitted the metal, you need to completely remove the bubbled paint and rust scale and then kill the rust with acid. Sandblasting is better than grinding.
Undercoating is fine for soundproofing but it will trap moisture and accelerate rusting.
Get the POR-15 trail size kit, and carefully follow the instructions.
CJ7-Tim is offline
post #5 of 8 Old 06-08-2010, 05:36 AM Thread Starter
jmolare
The clear coat is still in place over the rusty welds. Not sure that putting more paint over the rust will improve anything.
Could the rust be from a galvanic action between the steel in the door panel and the alloys in the weld? If that is the case, then grinding off the clear coat and treating the rust will not stop the welds from continuing to rot.
jmolare is offline
post #6 of 8 Old 06-08-2010, 07:29 AM
gtome
No just putting paint over the rust wont help. Gotta get rid of the rust first. There is a good chance it is rusting from the inside. I agree that sandblasting would be better than grinding, but most guys dont have access to a blaster. If you can get rid of most of the rust, get it treated, and covered with epoxy, there is a good chance of success.
Personally I have had 100% success with stripping, treat with picklex, then if you cant see it when finished I use rust bullet, and if you can, I epoxy and paint. But like was said, if the rust is really bad it must be cut out and replaced.
gtome is offline
post #7 of 8 Old 06-08-2010, 01:20 PM
CJ7-Tim
CJ7-Tim's Avatar
Try living in a state where they spread salt by the ton on roadways to clear ice and snow. My Cherokees all have had minor rust issues. The best you can do to slow the rusting, is to remove the rust scale and paint down to the bare metal, treat the rust, and try to seal the metal from further moisture contact. If you are dealing with the seams at the bottom of the doors, the moisture also gets into the seam from inside the door. POR-15 makes a sealer that is the consistency of toothpaste and it is used to seal seams and fill small rust pinholes. I used the POR paint products on the outer seam and the sealer on the inside of the doors to seal the seams.
CJ7-Tim is offline
post #8 of 8 Old 06-08-2010, 04:40 PM
gtome
Hear ya there!! I lived in Iowa my whole life up to a year ago. Most all the cars I did you could throw a cat through every panel.
gtome is offline
93 XJ Door Removal somedayfamous Paint and Body 9 05-10-2010 10:43 PM
Adhesive Side Rocker Panels = crap? Blackdog4 Paint and Body 4 03-11-2010 06:52 PM
2000 wj grill fab jrjeff Paint and Body 1 03-06-2010 09:36 PM
How to Weld Body Panels Galvanised Sheet. Jeepaddict Paint and Body 4 03-01-2010 06:46 AM
TJ door painting, doing tomorrow badassjeep04 Paint and Body 2 02-23-2010 07:25 PM
