Rust,rust,rust,rust - JeepForum.com
post #1 of 3 Old 01-14-2011, 02:53 PM Thread Starter
lanecj5
1980 CJ5
Rust,rust,rust,rust
So I've got rust to remove.I've seen all over the forum frame off resto's etc.Somebody must have a suggestion...I'll use the grinder and cup brushes on the heavy stuff;so I don't have alot of heavy rust left ,but would like to get down to bare metal before coating.What is the best brush on or spray on RUST/PAINT remover you have used?
lanecj5 is offline
post #2 of 3 Old 01-15-2011, 09:09 PM
freeskier93
I would never suggest to just paint over rust...but IMO POR-15 is the best.
freeskier93 is offline
post #3 of 3 Old 01-18-2011, 10:48 AM
Zone
POR-15 prevents moisture and air from touching the metal. However, it does not contain a rust converter. You might first consider using a phosphoric wash to convert the remaining existing rust (iron oxide) to water-soluable iron phosphate. Then, use POR-15. You can usually find phosphoric wash products at professional paint stores.
Zone is offline
rust bryan1242 Paint and Body 7 10-13-2010 08:05 AM
rust.... what should i do? CoolGuyDave Paint and Body 15 07-21-2010 03:15 PM
Rust Issues Mini-Me26 Paint and Body 4 04-27-2010 01:14 PM
Rust!- 2001 TJ ryanrogers Paint and Body 3 04-08-2010 03:21 PM
Why so much Rust? turkish6 Paint and Body 14 11-13-2009 12:15 AM
