Replacing floor pans - JeepForum.com
post #1 of 6 Old 08-22-2012, 09:33 AM Thread Starter
bligon64
1974 CJ5
The other day i noticed that i need to replace my floor pans, so i ordered my new pans and they are in. Several videos have informed me that the best way to attach these is by butt welding them in. However I am not nearly skilled enough to weld 18 gauge steel and not completely screw it up.
Therefore i was thinking about using rivets and silicon caulk to seal the area where the new pans would be going in.
Does anyone know of a reason that this would not work?
as always much appreciation
bligon64 is offline
post #2 of 6 Old 08-22-2012, 09:06 PM
Ironworker709
Ironworker709's Avatar
That method won't work very long at all,plus it'll look crappy.
But there is a panel adhesive that would work well and being used alot in where folks have no welders or the required expereince to use one...
Here's the 3M panel adhesive,when these panel adhesives are used accordingly,they can be near as strong as a weld,follow the directions STRICTLY...you will also have to buy the gun to use....this stuff is a great alternative to welding non structural panels on a vehicle,it's been widely used in replacement panels and floor work in resto's and repairs.
You can also stop at your local auto body supply store and they will commonly have this on the shelf or the same adhesive but other brands....
3M 08115 Panel Bonding Adhesive
This is another one that some people say is better than 3M and commonly found at stores too...i've never used it,but have used the 3M and happy with it..
Products: FU110B - Fusor Metal Patch Panel Adhesive Bondline Control (Fast-Set) 7.6 oz., 6 case/qty.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 6 Old 08-28-2012, 11:31 AM Thread Starter
bligon64
1974 CJ5
Thanks for the input Ironworker709. I have slowly been cutting out the old floor pan, and it looks like crap under there. The supports for the floor pan are almost completely rusted out. I think i am just going to clean up what is left of the old support and weld some more material in to strengthen the support.
I have talked to some other people and they have recommended that i just braze the new floor pan in. I have access to acetylene, so that will be much cheaper than buying the expensive structural glue. I did however want to ask your opinion because i have been told that brazing is stronger than the adhesive and possibly even stronger than welding the pans in. Is this person correct about brazing being stronger than welding?
bligon64 is offline
post #4 of 6 Old 08-28-2012, 11:48 AM Thread Starter
bligon64
1974 CJ5
Im not sure if you can see how rusted the support is in this picture
bligon64 is offline
post #5 of 6 Old 08-28-2012, 07:06 PM
Photog2000
I too use the 3M panelbond all the time. The stuff is awesome and you dont need to worry about warping the metal from getting it hot. The stuff is like $35 for a tube and it will be enough to do what you want. Make freinds with someone at a local body shop and they may be able to sneak you a gun to use over a weekend or something. Heck if you were close by you could borrow mine.
Brazing used to be the thing to do back in the days before small mig welders were available to use in body shop applications. I never heard of anyone that still does it. It will warp worse than welding IMO.
Photog2000 is offline
post #6 of 6 Old 08-28-2012, 07:07 PM
Photog2000
Invest in some actual auto body seam seasler as well. Dont just use silicon or caulking. Its just wrong and seam sealer is not that expensive, and you use a standard caulking gun to apply it.
floor pans , rust repair
How I am repairing floor pans MKfarm Paint and Body 7 03-06-2014 03:57 PM
Cj6 floor pans shuey Paint and Body 2 02-18-2012 10:17 PM
replacing drivers floor board in a TJ 99TJtommy Paint and Body 3 11-23-2011 05:17 PM
Do these floor pans fit a 95 Wrangler? grivera Paint and Body 10 10-22-2011 07:38 PM
Rusty TJ floor Jbecker Paint and Body 1 10-13-2010 08:51 AM
