removing spray bedliner from exterior? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > removing spray bedliner from exterior?
Savvy/Currie Aluminum Control ArmsRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 02-23-2014, 07:10 PM   #1
craft211
I just purchased my second jeep, and the previous owner had sprayed bed liner on parts of the jeep. It looks like he didn't sand it first, as some of it is chipping off. Most doesn't want to come off though. Anyone have an idea. I'm trying to avoid damaging the paint under it. If I can. Thanks for any suggestions.
James
craft211 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 09:39 PM   #2
magnetman
Caveman Chemist
JeepForum 2012 Vendor Giveaway Participate
magnetman's Avatar
2011 JK Wrangler
If most is stuck good he probably did sand first but areas that were overlooked or scuffed inadequately are the ones with poor adhesion.
What's the final results you are looking for if you can remove this?
More bedliner or paint?
magnetman is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 10:18 AM   #3
rjbruzan
Looks like it will ruin the paint getting it off. BUT you can try tar remover,xylene or lacquer thinner. Some or all may cause damage to the original paint.
Good luck.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 01:04 PM   #4
craft211
I'm going to be putting some black diamond plate rocker side panels. But they only go about half way up the body to the door sill. So I want to get it off there and back to factory paint and then put the panels on.
Unread 02-27-2014, 01:41 PM   #5
thantos858
1974 CJ5
You won't get away without damaging the paint. I would just use a paint stripper and repaint. I have had really good luck with Klean-Strip aircraft stripper http://www.oreillyauto.com/site/c/de...ver+-+stripper If you use the stripper make sure to have plenty of air flow or a good respirator along with chemical gloves its some nasty stuff. I had chemo therapy nitrile gloves on and it ate through them and ended up burning a large section of my hand.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2014, 02:10 PM   #6
craft211
Well I took a new scraper to it. And it is coming off, but not all and what is coming off is leaving small bits that I cant scrape. So I'm going to try and get what i can off and then try a RAZR blade scraper tk get the small stuff. Worst case is I have to repaint.
Thanks for the help guys.
Unread 02-27-2014, 02:16 PM   #7
BEETROOT
Good luck. Previous owner of my TJ covered the entire inside of the tub with that crap. I had to go down to bare metal to get it off.
BEETROOT is offline   Reply With Quote Quick reply to this message
Unread 03-08-2014, 01:28 AM   #8
3X4X4
Mek
j
3X4X4 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2014, 05:01 PM   #9
Ironworker709
Ironworker709's Avatar
Originally Posted by 3X4X4 View Post
Mek
j
MEK will quickly eat the paint too.......
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...http://www.ironworkers.org/becoming/careers.aspx
Ironworker709 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2014, 07:23 PM   #10
Machinist
My last project was flaking and some held.I was going to repaint so I just wire wheeled it.That chit was everywhere and in the end my grinder was toast from sucking that garbage into the motor.
Machinist is offline   Reply With Quote Quick reply to this message
Unread 03-09-2014, 11:12 PM   #11
3X4X4
Should not unless it is rattle can paint. Most two part paints are at least moderately resistant to MEK.
J
Unread 03-09-2014, 11:35 PM   #12
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
This is correct. A standard lab test for high end paints is MEK rub resistance. If auto paint came off easily with MEK it would be a big problem.
Paint remover, scraping or sanding is the best way to get this clean to redo the way you want it. The kleen-strip aircraft remover mentioned below is prob the best I have seen and used.
J
Unread 03-16-2014, 05:52 PM   #13
Bigev
KCCO
Bigev's Avatar
Update? I'm sure others would like to know how to remove it for future reference.
KCCO
Bigev is offline   Reply With Quote Quick reply to this message
Unread 03-25-2014, 06:24 PM   #14
JeepWranglerNation
Post Deleted
JeepWranglerNation is offline   Reply With Quote Quick reply to this message
Unread 12-15-2014, 06:27 AM   #15
my1986cj7
an update or anyone who read the deleted post remember how this turn out. I've read all the other threads on this issue and wire wheel aircraft stripper seem to be the most posted. I unwisely put bedliner in the tub of my jeep 7 or so years ago when I first bought it. Now I'm restoring and would like to put por-15 down and paint the surface the color I want.
my1986cj7 is online now   Reply With Quote Quick reply to this message
