Removing rust spots - JeepForum.com
post #1 of 2 Old 05-25-2011, 11:17 AM Thread Starter
Marauder_Pilot
Marauder_Pilot's Avatar
Removing rust spots
My tub has developed some small rust spots over the years-there's a nasty one under the passenger side door panel and one under the license plate bracket, and some small ones on the fenders from rock chips and the like.
I'm planning to repaint my TJ in the near future, so how should I go about cleaning up those patches beforehand? Is my best bet just to grind them down to bare metal and paint them over with some rust-proof primer, or is there a better method?
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #2 of 2 Old 05-25-2011, 06:04 PM
srdart67
If the rust has not gone all the way through the metal you can grind it of or sand blast it. A wire wheel will work also as long as you can remove ALL of the rust with it. Once its bare metal use an etching primer over the clean metal.
srdart67 is offline
Rust,rust,rust,rust lanecj5 Paint and Body 2 01-18-2011 10:48 AM
rust bryan1242 Paint and Body 7 10-13-2010 08:05 AM
rust.... what should i do? CoolGuyDave Paint and Body 15 07-21-2010 03:15 PM
lite spots in paint weaver01 Paint and Body 7 05-03-2010 05:36 PM
Why so much Rust? turkish6 Paint and Body 14 11-13-2009 12:15 AM
