Removing rust and paint - JeepForum.com
post #1 of 11 Old 02-19-2013, 07:51 PM Thread Starter
Darryl45
1975 CJ5
Restoring my 75 CJ5 and I'm trying to decide if I should sand blast or sand the body down. I want to take it down to the metal because of some surface rust. Any suggestions would be greatly appreciated. It seems like sand blasting would be easier to get in the hard spots.
Darryl45 is offline
post #2 of 11 Old 02-22-2013, 09:18 AM
rjbruzan
A sand blaster in the hands of an inexperienced user does most damage. It warps flat panels. It does do a fabulous job at the nooks and cranies inside the tub. Naturaly the gauges ect must be remove or they will fill with sand.
My suggestion is blast the inside and sand the outside.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 11 Old 02-22-2013, 01:00 PM
Zone
I agree, have it media blasted by someone who knows what they're doing. I suggest using glass bead instead of sand.
Zone is offline
post #4 of 11 Old 02-23-2013, 07:40 PM
insaneinline
Try to get it soda blasted it does not damage panels
insaneinline is offline
post #5 of 11 Old 02-24-2013, 04:01 PM
NOCHEEPGAS
1980 CJ5
THe guy that did my CJ used a combination of sand and walnut shells to prevent warpage.
NOCHEEPGAS is offline
post #6 of 11 Old 02-24-2013, 08:13 PM
paintballwannab
Get it professionally blasted....Its going to cost a bit, but will be worth every penny when you consider the hours you would have into sanding.
paintballwannab is offline
post #7 of 11 Old 02-26-2013, 06:29 PM Thread Starter
Darryl45
1975 CJ5
Thanks for the responses. I'm going to find someone to do the media blasting. I'm sure there is someone around Memphis. I have already sand blasted the frame and running gear. Put Por15 on them and they look great. Now time to get the body done.
Darryl45 is offline
post #8 of 11 Old 02-26-2013, 07:42 PM
rjbruzan
Where are the pictures?
rjbruzan is offline
post #9 of 11 Old 02-28-2013, 05:19 PM
sigmarus
For sandblasting I would go with a professional. But thats just me, I have never tried doing it myself.
sigmarus is offline
post #10 of 11 Old 02-28-2013, 05:34 PM Thread Starter
Darryl45
1975 CJ5
I will get some pics up next time I get back to my shop. Been doing a lot of flying and haven't been able to my shop lately.
Darryl45 is offline
post #11 of 11 Old 03-02-2013, 07:14 PM
Gates72ss
sandblasting on the frame and heavy metal like that is fine, when it comes to the tub these guys have given you solid advice...many people go right at it to only find out they did more harm then good..
Gates72ss is offline
