Removing Rivets - JeepForum.com
post #1 of 9 Old 11-18-2009, 09:47 AM Thread Starter
chriswilson03
Removing Rivets
Removed the Renegade Package from my 92 YJ and there are some metal rivets holding little L shaped brackets on the fender wells that I need to remove, I borrowed a pic from another member here to show what I'm talking about, If someone can clue me in on how to remove these I would reall appreciate it. Thanks
Chris
chriswilson03 is offline
post #2 of 9 Old 11-18-2009, 10:42 AM
cidd
Drilling them out is the best way I now if you do it carfully you can just drill the head of the rivet off without harming the body underneth.
cidd is offline
post #3 of 9 Old 11-25-2009, 08:20 PM
89jeepstyle
I have previously drilled the head off and had no issues damaging the body.
89jeepstyle is offline
post #4 of 9 Old 11-25-2009, 08:28 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Drill them out.
If you have an MRO shop handy (or an MRO catalogue,) a set of centre drills come in VERY handy for removing rivet heads without undue body damage...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 9 Old 11-26-2009, 02:07 AM
Goobersbro
hey looky there another feller who removed his renegade package
I just punched mine out but thats because I'm building tubes on the front highlining the rear and putting rock sliders in the middle so pretty much I just have to weld in the holes, primer and cover with body armor.
My marshmallow build
Goobersbro is offline
post #6 of 9 Old 11-26-2009, 07:56 PM Thread Starter
chriswilson03
Yeap, didn't have much choice though as it had been wrecked on the front drivers side and the plastic was busted up, instead of replacing I just pulled it all off, luckly I didn't have any rust problems like yours when I pulled it off, all real clean course living in the South West helps with that.
post #7 of 9 Old 11-28-2009, 09:07 PM
Rprickett
Drilling them out, it is the easiest way
Rprickett is offline
post #8 of 9 Old 11-29-2009, 12:10 AM
Goobersbro
Like I said you can punch them out you already have a descent amount of welding and bondo work so punching them isn't really going to hurt IMO but drilling is the best way
post #9 of 9 Old 11-29-2009, 09:00 AM Thread Starter
chriswilson03
Thanks, drilled them an the heads popped off then punched them out, no problem, worked great, thanks again.
Removing Herculiner GroundAssault Paint and Body 15 05-24-2010 11:37 PM
Need Help - Removing Hand Painted Accents meon2wheels Paint and Body 3 02-08-2010 08:36 PM
